[Swift-user] oops failures on OSG
Ben Clifford benc at hawaga.org.uk
Sat Feb 21 03:15:28 CST 2009
On Fri, 20 Feb 2009, Mihael Hategan wrote:
> I can see no benefit in swift seeing one site as two, so I would recommend
> against doing this in general.
There's a similar situation where you have multiple sites sharing file
systems (for example, at CI) - using (for example) /home/benc/tmp as a
shared directory on the >1 clusters that have access to CI home directory
space will cause a similar problem if they're used simultaneously, I
think.
More information about the Swift-user mailing list
