[Swift-user] local coaster looking for credential (was Re: mixing	gram execution and local filesystem providers)
    Allan Espinosa
    aespinosa at cs.uchicago.edu
    Wed Feb  4 14:43:21 CST 2009
Do coasters always need a proxy certificate?  This was found in my log
when i executed using  the "local:pbs" job manager
Caused by: org.globus.gsi.GlobusCredentialException: [JGLOBUS-5] Proxy
file (/tmp/x509up_u1600) not found.
        at org.globus.gsi.GlobusCredential.<init>(GlobusCredential.java:114)
        at org.globus.gsi.GlobusCredential.reloadDefaultCredential(GlobusCredential.java:590)
full log in: http://www.ci.uchicago.edu/~aespinosa/swift/blast-20090204-1438-9vr02924.log
sites.xml:
  <pool handle="TERAPORT" sysinfo="INTEL32::LINUX">
    <profile namespace="globus" key="queue">fast</profile>
key="coasterWorkerMaxwalltime">00:30:00</profile>
    <execution provider="coaster" url="none"  jobmanager="local:pbs" />
    <gridftp url="local://localhost" />
    <workdirectory >/disks/tp-gpfs/scratch/aespinosa</workdirectory>
  </pool>
-Allan
On Tue, Feb 3, 2009 at 6:11 PM, Ben Clifford <benc at hawaga.org.uk> wrote:
> On Tue, 3 Feb 2009, Allan Espinosa wrote:
>> Does this mean that the "cp" calls fail after a while?
> It means something failed. In the log, I see this:
>> org.globus.cog.abstraction.impl.common.task.InvalidSecurityContextException:
> Invalid GSSCredentials
> and
>> Caused by: GSSException: Defective credential detected [Caused by:
>> [JGLOBUS-5] Proxy file
>> (/home/aespinosa/.globus/job/tp-grid1.ci.uchicago.edu/11827.1233702664/x509_up)
> not found.]
> which is a strange looking error.
> I'd expect credential errors if your proxy just expired (please paste the
> output of grid-proxy-info from the same session that you ran this swift
> invocation from, if you still have it).
> But I wouldn't expect the error message to have a path to a credential
> inside what looks like the remote job directory.
More information about the Swift-user
