[Swift-user] mixing gram execution and local filesystem providers
Allan Espinosa
aespinosa at cs.uchicago.edu
Mon Feb 2 14:11:54 CST 2009
yes its the same sites.xml file. Here is the log of the successful gt2:gt2:pbs
http://www.ci.uchicago.edu/~aespinosa/swift/blast-20090202-1357-98hzn0n1.log
On Mon, Feb 2, 2009 at 2:06 PM, Ben Clifford <benc at hawaga.org.uk> wrote:
> On Mon, 2 Feb 2009, Allan Espinosa wrote:
>> I got the error below when running from a remote machine. But when i
>> submit the gt2:gt2:pbs from the gt2 server. I was able to execute the
>> job successfully.
> Using the same configuration on both the 'remote machine' and 'the gt2
> server'?
> My understanding is that wherever you submit from, you should get the same
> error no matter where you submit from; so I'd like to investigate that.
More information about the Swift-user
