[Swift-user] Re: swift on jazz
Marcin Hitczenko
marcin at galton.uchicago.edu
Thu Aug 27 10:54:38 CDT 2009
I am actually observing the former, which is why I thought this might be
controllable via swift.
I also have a few other basic questions regarding following job status and
organization of all the output files. I think the easiest thing to do
would be to look at my account together. Is there any way that we could
meet this week?
Marcin
> Hi Marcin,
> I took the liberty of moving this thread to swift-user for others to
> help me answer you, and for other users to benefit.
> On Jazz, are you observing that Swift only puts at most 2 jobs in the
> Jazz PBS queue (where you can see them with "qstat") or that Swift puts
> many jobs in the queue but only 2 run at a time?
> Assuming its the latter, you must be bumping in Jazz's scheduler policy
> which is favoring multi-CPU jobs. If thats the case, then lets try
> running the "coaster" provider which is specified in the sites.xml file.
> (tc.data doesnt change).
> First, change your "jazz" entry in sites.xml from the PBS execution
> provider:
> <execution provider="pbs" url="none" />
> to the Coaster provider:
> <execution provider="coaster" url="none" jobmanager="pbs:local" />
> This should work, although we may need to add additional XML
> specifications for timilimits, accounts, and maybe queues.
> Then we expect to be applying a fix to the coaster rpovider tonight, so
> we'll need to do a custom Swift build from the source repository after
> that, and test the latest fix. The fix improves the throughput, but even
> without it, you should see Swift requesting more CPUs from PBS in a
> single job.
> I suggest getting started with this simple change, and we'll enhance it
> in stages to give you better performance and more parallelism.
> - Mike
> On 8/26/09 3:20 PM, Marcin Hitczenko wrote:
>> ... I am running jobs on jazz and I noticed that jazz will only run
>> at most two jobs at once for me (I have about 30), even though there are
>> more nodes free and I am requiring only one node per job. Is there
>> something I can do to change this? Would I have to change the tc.data or
>> sites.xml file?
>> Thanks,
>> Marcin
More information about the Swift-user
