[Swift-user] Fwd: Problems getting started with coasters
Andriy Fedorov
fedorov at bwh.harvard.edu
Tue Aug 25 09:58:04 CDT 2009
I have a processing step that takes somewhere ~2-5 min. It takes on
input two ~5Mb files, and produces a small text file, which I need to
store. I need to compute large number of such jobs, using different
parameters. It seems to me "coaster" is the best execution provider
for my application.
Trying to start simple, I am running first.swift (echo) example that
comes with Swift using different providers: GT2, GT4, GT2/coaster, and
GT4/coaster. All of this is done on Abe NCSA cluster.
Here's my sites.xml:
<pool handle="Abe-GT4">
<gridftp url="gsiftp://gridftp-abe.ncsa.teragrid.org:2811/" />
<execution provider="gt4" jobmanager="PBS"
url="https://grid-abe.ncsa.teragrid.org:8443/wsrf/services/ManagedJobFactoryService"/>
<workdirectory>/u/ac/fedorov/scratch-global/scratch</workdirectory>
</pool>
<pool handle="Abe-GT4-coasters">
<execution provider="coaster" jobmanager="gt4:gt4:pbs"
</pool>
<pool handle="Abe-GT2">
<execution provider="gt2" jobmanager="PBS"
url="grid-abe.ncsa.teragrid.org:2119/jobmanager-pbs"/>
</pool>
<pool handle="Abe-GT2-coasters">
<execution provider="coaster" jobmanager="gt2:gt2:pbs"
url="grid-abe.ncsa.teragrid.org"/>
<filesystem provider="coaster" url="gt2://grid-abe.ncsa.teragrid.org" />
</pool>
And tc.data is simply
Abe-GT4-coasters echo /bin/echo INSTALLED INTEL32::LINUX null
and I change the site to test different providers.
Now, results:
1) both GT2 and GT4 providers work fine, script completes
2) with GT2+coaster provider, I can see the job in the PBS queue
(requested time is 01:41, I guess this comes with the default coaster
parameters, that I didn't change). The job appears to finish
successfully, and it seems like the output file is fetched back, but
then I get this error:
Final status: Finished successfully:1
START cleanups=[[first-20090825-0925-emkt2qt0, Abe-GT2-coasters]]
START dir=first-20090825-0925-emkt2qt0 host=Abe-GT2-coasters
Sending Command(21, SUBMITJOB) on GSSSChannel-null(1)
Command(21, SUBMITJOB) CMD: Command(21, SUBMITJOB)
GSSSChannel-null(1) REPL: Command(21, SUBMITJOB)
Submitted task Task(type=JOB_SUBMISSION,
identity=urn:0-1-1251210343871). Job id:
urn:1251210343871-1251210376098-1251210376099
Unregistering Command(21, SUBMITJOB)
GSSSChannel-null(1) REQ: Handler(JOBSTATUS)
Task(type=JOB_SUBMISSION, identity=urn:0-1-1251210343871) Completed.
Waiting: 0, Running: 0. Heap size: 65M, Heap free: 42M, Max heap: 227M
END dir=first-20090825-0925-emkt2qt0 host=Abe-GT2-coasters
Cleaning up...
Shutting down service at https://141.142.68.180:45552
Got channel MetaChannel: 500265006 -> GSSSChannel-null(1)
Sending Command(22, SHUTDOWNSERVICE) on GSSSChannel-null(1)
Command(22, SHUTDOWNSERVICE) CMD: Command(22, SHUTDOWNSERVICE)
Command(22, SHUTDOWNSERVICE): handling reply timeout
Command(22, SHUTDOWNSERVICE): failed too many times
org.globus.cog.karajan.workflow.service.ReplyTimeoutException
at org.globus.cog.karajan.workflow.service.commands.Command.handleReplyTimeout(Command.java:241)
at org.globus.cog.karajan.workflow.service.commands.Command$Timeout.run(Command.java:246)
at java.util.TimerThread.mainLoop(Timer.java:512)
at java.util.TimerThread.run(Timer.java:462)
- Done
3) with GT4-coaster provider, I don't get as far as with GT2-coaster.
Possibly I am not setting up properly the site entry. I was not able
to find any examples in the manual how to set coasters with GT4 (can
anyone provide an example?). Here's the error:
Failed to transfer wrapper log from
first-20090825-0929-39x94x09/info/t on Abe-GT4-coasters
END_FAILURE thread=0 tr=echo
Progress: Failed:1
Execution failed:
Exception in echo:
Arguments: [Hello, world!]
Host: Abe-GT4-coasters
Directory: first-20090825-0929-39x94x09/jobs/t/echo-t5oymmfj
stderr.txt:
stdout.txt:
Caused by:
Cannot submit job: Limited proxy is not accepted
Can anybody help figuring this out?
Thanks
Andriy Fedorov, Ph.D.
Research Fellow
Brigham and Women's Hospital
Harvard Medical School
75 Francis Street
Boston, MA 02115 USA
More information about the Swift-user
