[Swift-user] XDTM
    Mihael Hategan
    hategan at mcs.anl.gov
    Fri Aug 14 12:09:43 CDT 2009
On Fri, 2009-08-14 at 11:55 -0500, Michael Wilde wrote:
> On 8/14/09 11:30 AM, Mihael Hategan wrote:
> > On Fri, 2009-08-14 at 10:38 -0500, Michael Wilde wrote:
> >>>    5. I am still confused when talk about XML Data Type and Mapping.
> >>>       Where is the XML representation?  Is it the .xml that gets
> >>>       generated when run the swift code?
> >> No, the XML - if indeed it still exists - is only internal. I described
> >> it this way in an earlier post:
> > The Swift type declarations are "compiled" into XML schema since XML
> > schema is sufficiently powerful to express the structure of Swift
> > user-declared types. That piece appears in the <types></types> header of
> > a .kml file. However, it has nothing to do with mapping, so it's
> > probably not to be called XDTM.
> Mihael, thanks for clarifying.
> In the XDTM paper we described the use of XML schema this way:
> "In XDTM, a dataset’s logical structure is specified
> via a subset of XML Schema, which defines primitive
> scalar data types such as Boolean, Integer, String, Float,
> and Date, and also allows for the definition of complex
> types via the composition of simple and complex types."
> In other words, what you say above: that XML Schema is used to define
> Swift user-declared types.
Right. It's arguable whether that has much to do with XDTM. Using XML
schema to describe types/structure is the natural thing to do if you're
using XML and you need to describe types/structure.
I other words I think XDTM is confusing and the ambiguity above should
not prevent us from saying that it isn't used in Swift.
More information about the Swift-user
