[Swift-user] errors in file transfer
Yue, Chen - BMD yuechen at bsd.uchicago.edu
Wed Apr 29 16:06:28 CDT 2009
Hi Mihael,
I deleted the following line in my sites.xml file for NCSA_Abe and the wrapper transfer warnings are gone.
<profile namespace="globus" key="queue">fast</profile>
I can also find jobs queuing on Abe. However, after quite a while, no job returned. I guess it is because I didn't set a priority and all the jobs are waiting. Is there other way to set priority? I will try again later.
I then tested the IU BigRed with my application. Swift showed me the following error and I don't know if this is because of my setting:
Progress:  Selecting site:1019  Initializing site shared directory:4
Execution failed:
        Could not initialize shared directory on IU_BigRed
Caused by:
        org.globus.cog.abstraction.impl.file.FileResourceException: Error communicating with the GridFTP server
Caused by:
        Server refused performing the request. Custom message: Server refused GSSAPI authentication. (error code 1) [Nested exception message:  Custom message: Unexpected reply: 530-globus_xio: Server side credential failure
530-globus_gsi_gssapi: Error with GSI credential
530-globus_gsi_gssapi: Error with gss credential handle
530-globus_credential: Error with credential: The host credential: /etc/grid-security/hostcert.pem
530-     with subject: /C=US/O=National Center for Supercomputing Applications/CN=gridftp4.bigred.teragrid.iu.edu
530-     has expired 4459 minutes ago.
530-
530 End.]
The log for this search is at :
/home/yuechen/PTMap2/PTMap2-unmod-20090429-1553-vz669563.log
In the sites.xml, the entry for the BigRed is :
 <pool handle="IU_BigRed">
    <gridftp url="gsiftp://gridftp.bigred.iu.teragrid.org"/>
    <execution provider="coaster" url="gatekeeper.bigred.iu.teragrid.org" jobManager="gt2:fork"/>
    <workdirectory>/N/u/tg-yuechen/BigRed/swiftwork</workdirectory>
 </pool>
Thank you for help!
Chen, Yue
From: Mihael Hategan [mailto:hategan at mcs.anl.gov]
Sent: Wed 4/29/2009 2:19 PM
To: Yue, Chen - BMD
Cc: swift user
Subject: RE: [Swift-user] errors in file transfer
On Wed, 2009-04-29 at 14:04 -0500, Yue, Chen - BMD wrote:
> Hi Mihael,
> I tried the setting but it still gives me the following error:
> Failed to transfer wrapper log from
> PTMap2-unmod-20090429-1402-b5t8cqua/info/q on NCSA_Abe
> PTMap2-unmod-20090429-1402-b5t8cqua/info/m on NCSA_Abe
> PTMap2-unmod-20090429-1402-b5t8cqua/info/l on NCSA_Abe
> PTMap2-unmod-20090429-1402-b5t8cqua/info/9 on NCSA_Abe
> PTMap2-unmod-20090429-1402-b5t8cqua/info/f on NCSA_Abe
> PTMap2-unmod-20090429-1402-b5t8cqua/info/k on NCSA_Abe
> PTMap2-unmod-20090429-1402-b5t8cqua/info/7 on NCSA_Abe
Those are more like warnings, not errors.
The real error should be displayed towards the end of the run. Anyway,
it says:
"org.globus.gram.GramException: The provided RSL 'queue' parameter is
invalid"
This email is intended only for the use of the individual or entity to which it is addressed and may contain information that is privileged and confidential. If the reader of this email message is not the intended recipient, you are hereby notified that any dissemination, distribution, or copying of this communication is prohibited. If you have received this email in error, please notify the sender and destroy/delete all copies of the transmittal. Thank you.
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20090429/f9b3e88e/attachment.html>
More information about the Swift-user mailing list
