[Swift-user] job waiting
Ben Clifford benc at hawaga.org.uk
Sat Apr 18 17:01:16 CDT 2009
On Sat, 18 Apr 2009, Yue, Chen - BMD wrote:
> MOAB_INFO:  job exceeded wallclock limit
This message means that some of the josb that you tried to run took longer
than is allowed by default.
I plotted your logs using swift-plot-log, and from the graph 'karajan
active JOB_SUBMISSION cumulative duration' in the karajan tab
(http://www.ci.uchicago.edu/~benc/tmp/report-PTMap2-unmod-20090418-1254-d8loarc1/karajan.html)
it looks like while most of your jobs take somewhere between seconds to a
few minutes, a number of your jobs take longer (up to 3000 seconds in that
graph)
Check that: i) an hour is a sane time for your programs to be taking, and
ii) that the queues that you are submitting to (the default on ncsa, for
example) allow this length of time.
More information about the Swift-user mailing list
