[Swift-user] consultation about error messages, coaster usage
    Michael Wilde
    wilde at mcs.anl.gov
    Mon Apr  6 23:15:36 CDT 2009
OK, will do. I think the fix you applied at 5PM enables us to go back to
the latest rev. This morning we updated, then reverted back to Tuesday 3/31.
On 4/6/09 10:08 PM, Mihael Hategan wrote:
> You seem to be using a particularly bad version of swift. I suggest
> trying the latest version.
> Mihael
> On Mon, 2009-04-06 at 21:42 -0500, Glen Hocky wrote:
>> Hi Guys,
>> I just ran (and killed) too big runs w/ swift, one on ranger, one on
>> abe. I stopped them because in each case there were many "Failed but can
>> retry" jobs, several "Failed to transfer wrapper log" errors and at the
>> point where i stopped them, many more cpu's allocated than "Active"
>> jobs. E.g. on ranger there were 14 running jobs in the queue w/ over an
>> hour left (so 224 cpus) but only 76 "Active" jobs.
>> Could someone take a look at the logs and tell me if things are working
>> properly? It's a little hard to tell from a user end...
>> On a ci home machine,
>> All run related files for abe are in
>>> /home/hockyg/oops/swift/output/abeoutdir.5/
>> and for ranger
>>> /home/hockyg/oops/swift/output/rangeroutdir.5/
>> In those directories, there will be a file $site.out.5 which has the stdout
>> and xout.XXXXX which has a log of all the commands run including the
>> swift invocation
>> the tc.data file used is $site.data and the sites.xml file is $site.xml
>> Thanks,
>> Glen
>> Swift-user mailing list
>> Swift-user at ci.uchicago.edu
>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
More information about the Swift-user
