[Swift-user] Re: installing swift
Marco Mambelli
marco at hep.uchicago.edu
Fri Apr 3 13:07:49 CDT 2009
Hi Ben,
the user owning the installation ran succesfully:
Swift 0.8 (stripped) swift-r2448 cog-r2261
RunID: 20090403-1305-k22hrieg
Progress:
Final status: Finished successfully:1
Another user had permission problems:
swift.log exists, it was created by the first user but it is writable
also by this one (I tryed to append something to it).
Which permission is looking for? does it need to be the owner? Group write
is not sufficient?
Should every user have its own swift installation?
Below the java trace.
Marco
[train02 at grid07 swift]$ swift first.swift
log4j:ERROR setFile(null,true) call failed.
java.io.FileNotFoundException: swift.log (Permission denied)
at java.io.FileOutputStream.openAppend(Native Method)
at java.io.FileOutputStream.<init>(FileOutputStream.java:177)
at java.io.FileOutputStream.<init>(FileOutputStream.java:102)
at org.apache.log4j.FileAppender.setFile(FileAppender.java:272)
at
org.apache.log4j.FileAppender.activateOptions(FileAppender.java:151)
at
org.apache.log4j.config.PropertySetter.activate(PropertySetter.java:247)
at
org.apache.log4j.config.PropertySetter.setProperties(PropertySetter.java:123)
at
org.apache.log4j.config.PropertySetter.setProperties(PropertySetter.java:87)
at
org.apache.log4j.PropertyConfigurator.parseAppender(PropertyConfigurator.java:645)
at
org.apache.log4j.PropertyConfigurator.parseCategory(PropertyConfigurator.java:603)
at
org.apache.log4j.PropertyConfigurator.configureRootCategory(PropertyConfigurator.java:500)
at
org.apache.log4j.PropertyConfigurator.doConfigure(PropertyConfigurator.java:406)
at
org.apache.log4j.PropertyConfigurator.doConfigure(PropertyConfigurator.java:432)
at
org.apache.log4j.helpers.OptionConverter.selectAndConfigure(OptionConverter.java:460)
at org.apache.log4j.LogManager.<clinit>(LogManager.java:113)
at org.apache.log4j.Logger.getLogger(Logger.java:94)
at org.globus.cog.karajan.Loader.<clinit>(Loader.java:43)
Could not start execution.
first.xml (Permission denied)
On Thu, 2 Apr 2009, Ben Clifford wrote:
> Yeah, that's quite out of date, it seems.
> If you're installing on a machine with an OSG stack, get the version
> without extra stuff (swift-0.8-stripped.tar.gz) from the download page.
> Untar it, and put its bin/ directory on your system path.
> The stripped version does not contain commands like grid-proxy-init, to
> avoid conflict with real versions deployed elsewhere (i.e. in an OSG
> install).
> To test, go into the examples/swift/ directory, type:
> swift first.swift
> and check that a file hello.txt appears.
More information about the Swift-user
