[Swift-user] Re: installing swift
    Michael Wilde
    wilde at mcs.anl.gov
    Thu Apr  2 17:19:28 CDT 2009
Hi Marco,
I am not sure about cog-setup, but I would skip that and proceed to the
examples, after putting bin/ in your path and making sure that you have
CA certificates so you can make a proxy (I assume you get all this from
your OSG environment).
(I assume that was removed on purpose and the quickstart was not updated
to reflect it. We need to fix that).
Note that Swift's bin/ provides some tools that are also in OSG bin dirs.
And you should direct all your questions to this list, swift-user,
because that's where the developers listen for users who need help.
To test if its working, do the first example in the Swift tutorial:
http://www.ci.uchicago.edu/swift/guides/tutorial.php
Then move on to the Swift tutorial for the OSG Grid School, I think,
would be the best approach.
- Mike
On 4/2/09 5:04 PM, Marco Mambelli wrote:
> Hi Mike,
> I'm setting up another host that could be used for the workshop (in case
> the VM has problem, to have a VDT supported platform).
> I need some help installing swift.
> I tried to follow the instructions in
> http://www.ci.uchicago.edu/swift/guides/quickstartguide.php
> The files cog-setup and example.swift are not in the tarfiles (version
> 8) that I downloaded.
> I don't know exactly how to configure it and/or test if it is working.
> Thank you,
> Marco
More information about the Swift-user
