[Swift-user] Why so few nodes ?
Ben Clifford
benc at hawaga.org.uk
Tue Sep 23 11:54:10 CDT 2008
On Tue, 23 Sep 2008, Xueyuan Zhou wrote:
> thanks, I remember it seems if I only use teraport, it is just half nodes. I
> will try again go make sure.
It will be half, through out the whole run. To use more, you can adjust
the jobThrottle parameter.
I'm not sure which is better to use - the gt2 provider or the pbs
provider. The gt2 provider is much more tested; the pbs provider might put
less load on the head node (or might not) - not many people have used it.
More information about the Swift-user
