[Swift-user] Why so few nodes ?
Ben Clifford
benc at hawaga.org.uk
Tue Sep 23 11:02:13 CDT 2008
On Mon, 22 Sep 2008, Xueyuan Zhou wrote:
> /home/zhouxy/dic_parser/swift_script2 has a succesful complete log, with mush
> smaller input file than
I plotted that log file here:
http://www.ci.uchicago.edu/~benc/tmp/report-test3-20080922-2040-h1383jdc/
The log file seems to suggest that between 5 and 12 jobs are running at
any one time according to the submit side after about 200 seconds into the
run.
To begin with, each site will only get two nodes at once; as your run
progresses successfully on a site, that site will be given more nodes.
Have a look at the graph labelled:
execute2 tasks, coloured by site
and you can see how many jobs are sent to each site at once.
You have two sites defined - localhost and teraport. The localhost
definition looks a bit suspicious, though - the usual swift localhost
definition never allows more than 2 jobs to run at once, but on your run
you often have more than that.
What does your sites.xml file look like?
More information about the Swift-user
