[Swift-user] Swift+MPI+LSF
Mihael Hategan hategan at mcs.anl.gov
Fri Sep 19 12:45:48 CDT 2008
On Fri, 2008-09-19 at 13:27 -0400, Andriy Fedorov wrote:
> On Fri, Sep 19, 2008 at 1:13 PM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> > It looks like it works on other sites too (I tried mercury at ncsa, which
> > has PBS). So it looks like UC is broken in this respect. I'll send a
> > ticket to TG.
> UC is different from other TG sites, because it is heterogeneous. You
> need to use something more than just "count", because you need to pass
> "compute" type to the node specs. I use "host_types" on UC, and it
> works for me...
I see little reason to not have "count" work. And if not, things should
be documented properly.
More information about the Swift-user mailing list
