[Swift-user] Swift+MPI+LSF
Andriy Fedorov
fedorov at cs.wm.edu
Fri Sep 19 12:04:10 CDT 2008
On Fri, Sep 19, 2008 at 12:46 PM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> On Fri, 2008-09-19 at 10:22 -0400, Andriy Fedorov wrote:
>> Hi,
>> I am trying to use Swift to run an MPI job via LSF scheduler (TG
>> Lonestar, http://www.tacc.utexas.edu/services/userguides/lonestar/).
>> Previously, I had problems running stuff like this with PBS (see
>> http://mail.ci.uchicago.edu/pipermail/swift-user/2008-July/000443.html).
>> Right now I am using the solution suggested by Ben (submit single node
>> job, and run a shell wrapper to launch mpirun, ). This doesn't seem to
>> work with LSF. I specify "GLOBUS::jobType=single,host_xcount=10", and
>> have my shell wrapper run
> Try "count" instead of "host_xcount".
This was indeed the solution. It seems to work. Thank you, Mihael!
More information about the Swift-user
