[Swift-user] what is wrong with restart5.swift?
Ben Clifford benc at hawaga.org.uk
Sun May 25 14:22:57 CDT 2008
On Sun, 25 May 2008, Mihael Hategan wrote:
> Should be fixed in r2004.
runs ok without restarts using r2004.
I put it in tests/misc/restart5.sh, as three runs:
  i) runs without restart, expecing a succesful end.
  ii) run with B set to fail and A and C set to succeed, expecting a fail
  iii) restart the run from ii) with A set to fail and B and C set to
succeed, expecting success.
This should check that all of the A jobs get run the first time and that
their output is logged for restart successfully (because A cannot be
called in part iii).
During my viewing of Eurovision last night, I was poking round with some
of the stuff I talked about wrt scope identification.
As far as I can tell, at the moment, the way that
VDLFunction.getThreadPrefix works at the moment is roughly the "right
thing" to do as far as that is concerned:
New SwiftScript scopes are always represented in Karajan as a new thread;
and those threads are labelled by their position in the source code
(because they get numbered in accordance with their position in a
<parallel> block, so this is invariant wrt restarts) or, if a stack frame
has a $ variable (the foreach iteration variable container) then the
position in the array being iterated is used instead of the thread number.
This is pretty much the behaviour I think is desirable (modulo the fact
that this implementation probably doesn't work for iterate{} but I think
that is easily fixable).
So I think filename based concurrent mapping works with restarts
(modulo iterate{}).
I also think that is(was?) the only correctness problem with restarts at
the moment.
More information about the Swift-user mailing list
