[Swift-user] Questions
J A
jamalphd at gmail.com
Mon May 12 17:38:03 CDT 2008
Hi Ben:
Thanks for your reply.
Does any one have an example on how to do item # 2 below?
Thanks for your cooperation.
Jamal
On 5/12/08, Ben Clifford <benc at hawaga.org.uk> wrote:
> On Mon, 12 May 2008, J A wrote:
> > > 1. Can i run swift in a windows application? if yes, how?
> You probably can run Swift on Windows as a client, but you will need a
> unix box to perform the actual execution of work.
> > > 2. Can i call other code (written in another language) from swift?
> Swift calls out to unix executables; if you can compile your code into a
> unix executable, then you can call your code that way.
> It will not be a JNI / function level link. It will be using Swift's file
> transfer+execute mechanism for calling executables:
> input data files are copied to whichever machine you will run on
> your code is executed
> output data files are copied back
> > > 3. How can swift work with PBS?
> There are a couple of mechanisms. If you are running on the head node of a
> PBS cluster, you can use the PBS execution provider. If you are submitting
> to a cluster which has Globus GRAM and PBS both instaleld, then you can
> use one of the GRAM execution providers. The choice of provider is
> specified in the site catalog, libexec/sites.xml.
> The user guide contains a section '16. The site catalog' which gives some
> details about configuring this.
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20080512/cb1484b6/attachment.html>
More information about the Swift-user
