[Swift-user] Workflow handling a large parallelism ?
    Ben Clifford
    benc at hawaga.org.uk
    Wed May  7 10:45:47 CDT 2008
On Wed, 7 May 2008, Tiberiu Stef-Praun wrote:
> This worked, thank you !
> The simple_mapper is a bit unintuitive, I would call it
> sequential_file_mapper or something like that
no more renaming!
> and remove the limitation that file names get only 4 digits generated
> automatically (and zero-padded).
Perhaps precision parameters that allow: padding to be specified (and to
what width) or no padding. So you might say padding=4 to get 4 digits (the
present behaviour) or padding=0 to get no padding at all. This is listed
as bug 139 now.
This is only necessary for output files.
For input files, the names already exist, though there is a bug open about
some other aspect of this causing a problem (bug 116).
More information about the Swift-user
