[Swift-user] Re: [falkon-user] 1) disable retry mechanism and 2) continue on failure?
Zhao Zhang
zhaozhang at uchicago.edu
Mon Mar 31 02:37:12 CDT 2008
Thanks, Ben
zhao
Ben Clifford wrote:
> On Mon, 31 Mar 2008, Ben Clifford wrote:
>> This temporary directory handling is pretty ugly - it should be a couple
>> lines change to wrapper.sh to get similar functionality using the existing
>> swift temporary direcotry handling - change the path to /tmp and use cp
>> instead of ln -s. That way you can take advantage of Swift's existing
>> unique job IDs and error handling too.
> Attached are three patches that will apply against svn r1775:
> The first puts temporary directories in /tmp rather than on shared fs.
> http://www.ci.uchicago.edu/~benc/tmp/wrapper-tmp-dirs-on-tmp
> The second copies the application file to the worker in each job execution
> (though doesn't do any worker-node caching of such between jobs)
> http://www.ci.uchicago.edu/~benc/tmp/wrapper-tmp-dirs-mv-executable
> The third creates the worker node log on /tmp and copies it at the end.
> http://www.ci.uchicago.edu/~benc/tmp/wrapper-tmp-log-locally
> The three modify all wrapper.sh and should be applied in the above order.
> With the first two patches, the timestamps in the usual info logs will
> provide information about how long the copies take, in the same way that
> they usually indicate times for other execution stages.
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20080331/bcb964e3/attachment.html>
More information about the Swift-user
