[Swift-user] debug log not being produced
Ben Clifford benc at hawaga.org.uk
Sat Mar 29 23:29:59 CDT 2008
I just tried to look at your cog checkout in ~quanpt/cog but you have
permissions set to not allow that so I can't look.
$ ls -ld ~quanpt/cog
drwx------  12 quanpt ci-users 4096 Mar 29 22:51 /home/quanpt/cog
On Sat, 29 Mar 2008, Quan Tran Pham wrote:
> Hi,
> I am in the same situation, the log is not written out with my swift
> script that run fine before.
> The script was fine with Swift v0.3-dev r1684 (it did produce the log).
> My new swift + falkon: Swift svn swift-r1773 cog-r1953 (compiled
> follow http://dev.globus.org/wiki/Incubator/Falkon/Swift)
> I am running swift on Teraport tp-login2.ci
> JRE: Standard Edition (build 1.5.0_06-b05)
> Should I use some explicit flags for swift so that it will build the log?
> Thank you very much
> Quan Pham
> On Sat, Mar 29, 2008 at 9:39 AM, Michael Wilde <wilde at mcs.anl.gov> wrote:
> > sorry, i didnt say clearly whats going on here:
> >  with a clean 1773 build, running first.swift (hello world), on
> >  terminable I get the log file fine, and on the bgp i get no log file.
> >  I will test on the bgp with the alternative Java 1.4 release in /usr/bin
> >  when I get a chance.
> >  - mike
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
More information about the Swift-user mailing list
