[Swift-user] How to wait on functions that return no data?
Michael Wilde
wilde at mcs.anl.gov
Tue Mar 25 10:14:40 CDT 2008
>> In the example below, I want collectResults() to get invoked after all
>> the runam() calls complete in doall().
> results = doall();
> collectResults(results);
> Mihael
But thats the problem: doall() does not in this example return results.
If it would return an artificial result, how would we get such a return
to wait until all the runam() calls made within the freach() have completed?
Each of the runam() call runs a small model, and in this proposed
scenario would leave those results on a local disk for later collection,
either in a single shared file that many invocations would append to, or
in a set of files.
Then collectresults() would run a job that collects all the data when done.
One approach can be to have collectresults() just run iteratively until
it has collected a sufficient number of results. I.e., to have it not
depend on swift to find out when all the runam() calls have completed.
That might work.
- Mike
On 3/25/08 10:00 AM, Mihael Hategan wrote:
> On Tue, 2008-03-25 at 09:46 -0500, Michael Wilde wrote:
>> For the petro-model app Im working on, it would be interesting to run
>> the parameter sweep in "map reduce" manner, in which each invocation
>> bites off a portion of the parameter space and processes it, resulting
>> in a set of result tuples. Each run of the model will produce a set of
>> tuples, and when all are done, we want to aggregate and plot the tuples.
>> While with batching this is not strictly needed, it would be interesting
>> to let the model results accumulate on the local filesystem (as in this
>> case they are small) and collect them either at the end of the run, or
>> periodically and perhaps asynchronously during the run.
>> To do this, we'd want to write the model invocation as a swift function
>> with only scalar numeric parameters, and no output.
> That assertion I'm not sure about.
>> The question is how to call a zero-returns function in a swift foreach()
>> loop, and embed that foreach() in a function that doesnt return until
>> all members of the foreach() have been processed.
> The very notion of "return" as it would appear in a strict language
> doesn't make much sense in Swift, so I'm not quite sure.
>> I havent tried to code this yet, because I cant think of a way to
>> express it in swift, due to the data-dependency semantics.
> results = doall();
> Mihael
>> Anyone have any ideas?
>> This is a low-priority question, just food for thought, as the batched
>> way of running this parameter sweep should be straightforward and efficient.
>> Mike
>> // Amiga-Mars Parameter Sweep
>> type amout;
>> runam (string id , string p1, string p2) // no ret val
>> app { runam3 id p1 p2 ; }
>> type params {
>> string id;
>> string p1;
>> string p2;
>> doall(params p[])
>> foreach pset in p {
>> runam(pset.id, pset.p1, pset.p2);
>> // waitTillAllDone();
>> // want to block here till all above finish,
>> // but no data to wait on. any way to
>> // achieve this???
>> // Main
>> params p[];
>> p = readdata("paramlist");
>> doall(p);
>> amout amdata <some mapping>;
>> amdata = collectResults();
>> // ^^^ Want collectresults to run AFTER all runam() calls finish
>> // in the doall() function.
>> Swift-user mailing list
>> Swift-user at ci.uchicago.edu
>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
More information about the Swift-user
