[Swift-user] iterate syntax
    Luciano Piccoli
    piccoli at fnal.gov
    Tue Mar 18 14:54:34 CDT 2008
I justed checked out the latest swift and it looks like the iterate
syntax changed. This code runs with revision 1673:
    iterate i {
      int trajectory = i;
    } until (@extractint(u0[i+1]) == @extractint(u0[i]));
Using revision 1735 I get this message:
    Could not start execution.
            Variable i is undefined
Defining the variable before the iterate block does not help:
            Variable i is already defined.
What would be the correct way to use iterate?
Luciano
More information about the Swift-user
