[Swift-user] Passing GRAM parameters
Andriy Fedorov fedorov at cs.wm.edu
Tue Jun 17 11:37:46 CDT 2008
Michael,
Thank you for this clarification. I will post an update if I have problems.
I am sorry I cannot try things out right away, but I am in the process
of setting up my software on TeraGrid, and it's going to take some
time... But I WILL have updates on whether this works or not,
eventually! :)
Andrey
On Tue, Jun 17, 2008 at 12:34 PM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> On Tue, 2008-06-17 at 12:21 -0400, Andriy Fedorov wrote:
>> >> 1. I have a workflow, which contains an MPI-parallelized component. I
>> >> haven't seen a reference on how explicitly parallel jobs can be
>> >> launched in the Swift guide. Is this functionality implemented, or
>> >> this requires extending Swift (writing a new site selector, maybe?)
>> > I've never done anything with MPI-parallel stuff in GRAM. I think tis is
>> > normally specified in GRAM RSL. Do you have a command for GRAM to do it?
>> I know how to do that in pre-WS GRAM -- there were "count" and
>> "hostCount" attributes. I assume, same attributes should work with WS
>> GRAM.
> An possibly jobType="mpi".
> Yes, the same attributes should work with WS-GRAM. If they don't, I
> would consider it a bug.
>> Can you tell me how to specify multiple GLOBUS::-like parameters? For
>> example, if I want to try to specify walltime, count and hostCount for
>> each item in tc.data, is this possible? I understand that I can
>> probably specify these attributes in sites.xml, but in this case the
>> resource request for that specific site will always ask for
>> "hostCount" nodes, even if I can only use 1.
> You should be able to separate them using commas, if they share the same
> namespace. For example:
> GLOBUS::walltime="10:10:00",count=4,hostCount=2
More information about the Swift-user mailing list
