[Swift-user] suggestion for program flow control
Mihael Hategan
hategan at mcs.anl.gov
Wed Jun 11 17:09:16 CDT 2008
> > Why is it that you don't want to pass a result file for
> > each of the
> > thousand processed files?
> laziness,
Fair enough an argument for me.
> and also I'm not sure what that should look like in the function definition?
> Is there a way I can make the argument list for the function dynamic since the number of result files will vary based on the selected database to process?
If I understand this correctly, then you can pass the whole array. You'd
get each file name on the command line. There's a question of whether
you'd cross the command line length limitation.
We should have array slices in Swift maybe?
> I can definitely see the benefit of having separate pipelines for non-dependent parts within the same script, but perhaps there is a way to chain dependent functions that is not dependent on files produced by previous functions?
Only that it is, but Swift has no idea about it. The dependency is
handled/created by your script.
> Like I said it wasn't a big deal to add the extra script to pause and count files, just different behavior than I expected from the loop code.
Right. If you look at it through the prism of an intuition constructed
by doing C and Java and the likes, it doesn't look right.
> > > Mike
> > > _______________________________________________
> > > Swift-user mailing list
> > > Swift-user at ci.uchicago.edu
> > http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
More information about the Swift-user
