[Swift-user] Illegal character
Greg Cross grog at ci.uchicago.edu
Tue Jul 29 14:08:09 CDT 2008
OSG sets dozens of environmental variables.  Normally this is done
through sourcing the setup.*sh files in $VDT_LOCATION, but softenv
does the same thing automatically with any "osg" macro.
Unfortunately, many variables get set that would otherwise be
unnecessary.  Unfortunately (and obviously) the result isn't always
desirable, and so you either have to remove it like you did or have
CLASSPATH and other variables defined/appended for swift (and
anything else that conflicts).
-- Greg
On Tue 29 Jul 2008, at 11:13, Zhengxiong Hou wrote:
> Hi Mike,
>    Yes,you are right.
>    If I unset CLASSPATH in .soft.cache.sh, or just mark
> #@osg in the .soft file, the original error disappeared.
>    But there is a new ERROR, although swift job was finished.
> [houzx at communicado dock]$ swift flipper.swift
> 2008.07.29 11:05:59.115 CDT: [ERROR] Parsing profiles on
> line 19 Illegal character '    'at position 5 :Illegal
> character '     '
> Swift 0.5 swift-r1783 cog-r1962
> RunID: 20080729-1105-qbqofzya
> Progress:
> convert started
> 2008.07.29 11:05:59.900 CDT: [ERROR] Parsing profiles on
> character '     '
> convert completed
> Final status:  Finished successfully:1 Finished:1
> Thanks much,
> zhengxiong
> ---- Original message ----
>> Date: Tue, 29 Jul 2008 09:35:05 -0500
>> From: Michael Wilde <wilde at mcs.anl.gov>
>> Subject: Re: [Swift-user] pegasus?
>> To: Zhengxiong Hou <zhengxiongh at uchicago.edu>
>> Cc: swift-user at ci.uchicago.edu, support at ci.uchicago.edu
>> See if you have CLASSPATH set, and have Pegasus jars in it.
>> Then try unsetting CLASSPATH and see if the same error
> occurs.
>> The Swift command should put the correct Swift jars in the
> final
>> classpath before any of your local jars, but perhaps
> there's some
>> strange dynamic class interaction between the Swift version
> of
>> tcdata/sites code and code that you have been experimenting
> with from
>> the Peagsus release (eg get-sites etc).
>> - Mike
>> On 7/29/08 9:22 AM, Zhengxiong Hou wrote:
>>> Hi,
>>>   Recently, I met with an error when using Swift:
>>> [houzx at communicado results]$ swift -sites.file ./sites-
>>> 20.xml -tc.file ./tc.data grid-many-dock6-auto.swift
>>> 2008.07.29 08:45:37.416 CDT: [FATAL ERROR] You forgot to
>>> set -Dpegasus.home=$PEGASUS_HOME!
>>> 2008.07.29 08:55:56.512 CDT: [FATAL ERROR] You forgot to
>>>   Swift did NOT need this. Is there anything wrong with
> my
>>> account at CI?
>>> [houzx at communicado dock]$ echo $PEGASUS_HOME
>>> /soft/osg-client-1.0.0-r1/pegasus
>>> [houzx at communicado dock]$ cd ~
>>> [houzx at communicado ~]$ cat .soft
>>> # This is your SoftEnv configuration run control file.
>>> #   It is used to tell SoftEnv how to customize your
>>> environment by
>>> #   setting up variables such as PATH and MANPATH.  To
> learn
>>> more
>>> #   about this file, do a "man softenv".
>>> @default
>>> @osg
>>> @globus-4
>>> Thanks!
>>> Zhengxiong
>>> _______________________________________________
>>> Swift-user mailing list
>>> Swift-user at ci.uchicago.edu
>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
More information about the Swift-user mailing list
