[Swift-user] Illegal character
Zhengxiong Hou
zhengxiongh at uchicago.edu
Tue Jul 29 11:13:30 CDT 2008
Hi Mike,
Yes,you are right.
If I unset CLASSPATH in .soft.cache.sh, or just mark
#@osg in the .soft file, the original error disappeared.
But there is a new ERROR, although swift job was finished.
[houzx at communicado dock]$ swift flipper.swift
2008.07.29 11:05:59.115 CDT: [ERROR] Parsing profiles on
line 19 Illegal character ' 'at position 5 :Illegal
character ' '
Swift 0.5 swift-r1783 cog-r1962
RunID: 20080729-1105-qbqofzya
Progress:
convert started
2008.07.29 11:05:59.900 CDT: [ERROR] Parsing profiles on
character ' '
convert completed
Final status: Finished successfully:1 Finished:1
Thanks much,
zhengxiong
---- Original message ----
>Date: Tue, 29 Jul 2008 09:35:05 -0500
>From: Michael Wilde <wilde at mcs.anl.gov>
>Subject: Re: [Swift-user] pegasus?
>To: Zhengxiong Hou <zhengxiongh at uchicago.edu>
>Cc: swift-user at ci.uchicago.edu, support at ci.uchicago.edu
>See if you have CLASSPATH set, and have Pegasus jars in it.
>Then try unsetting CLASSPATH and see if the same error
occurs.
>The Swift command should put the correct Swift jars in the
final
>classpath before any of your local jars, but perhaps
there's some
>strange dynamic class interaction between the Swift version
of
>tcdata/sites code and code that you have been experimenting
with from
>the Peagsus release (eg get-sites etc).
>- Mike
>On 7/29/08 9:22 AM, Zhengxiong Hou wrote:
>> Hi,
>> Recently, I met with an error when using Swift:
>> [houzx at communicado results]$ swift -sites.file ./sites-
>> 20.xml -tc.file ./tc.data grid-many-dock6-auto.swift
>> 2008.07.29 08:45:37.416 CDT: [FATAL ERROR] You forgot to
>> set -Dpegasus.home=$PEGASUS_HOME!
>> 2008.07.29 08:55:56.512 CDT: [FATAL ERROR] You forgot to
>> Swift did NOT need this. Is there anything wrong with
my
>> account at CI?
>> [houzx at communicado dock]$ echo $PEGASUS_HOME
>> /soft/osg-client-1.0.0-r1/pegasus
>> [houzx at communicado dock]$ cd ~
>> [houzx at communicado ~]$ cat .soft
>> # This is your SoftEnv configuration run control file.
>> # It is used to tell SoftEnv how to customize your
>> environment by
>> # setting up variables such as PATH and MANPATH. To
learn
>> more
>> # about this file, do a "man softenv".
>> @default
>> @osg
>> @globus-4
>> Thanks!
>> Zhengxiong
>> Swift-user mailing list
>> Swift-user at ci.uchicago.edu
>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
More information about the Swift-user
