[Swift-user] Using > 1 CPU per compute node under GRAM
    Ben Clifford
    benc at hawaga.org.uk
    Tue Jul 22 02:19:57 CDT 2008
On Mon, 21 Jul 2008, Michael Wilde wrote:
> In the meantime, does anyone know if there's a way to specify
> compute-node-sharing between separate single-cpu jobs via both GRAMs?
> And if this is dependent on the local job manager code or settings? (Ie might
> work on some sites but not others)?
You can specify via GRAM RSL; however at least TGUC deliberately does not
allow that - one job gets an entire node. I imagine other sites are
similar.
Coasters should allow this to be done, by running two coaster workers on
one node. I plan to look at doing that sometime.
> This will ideally be handled as desired by Falkon or Coaster, but in the
> meantime I was hoping there was a simple setting to give MikeK better
> CPU yield on Abe.
There isn't.
Him and I have investigated this before, I think. I've just put this in
the swift bugzilla as bug 150.
More information about the Swift-user
