[Swift-user] Re: GT4
Mihael Hategan hategan at mcs.anl.gov
Sat Jul 19 11:17:01 CDT 2008
On Sat, 2008-07-19 at 11:10 -0500, lixi at uchicago.edu wrote:
> >For GRAM4 on that machine you need (by the looks of it) to
> use tcp port
> >9443, not the default 8443 which is running some other
> services. I think
> >this will in general be true for all OSG resources.
> How to change it? Does it like this:
> <pool handle="AGLT2">
>    <gridftp  url="gsiftp://gate01.aglt2.org" />
>    <execution provider="gt4" jobmanager="CONDOR"
> url="gate01.aglt2.org:9443" />
>    <workdirectory >/atlas/data08/OSG/DATA</workdirectory>
> </pool>
Yes.
> >You could try the above two commands yourself and see what
> you get.
> [lixi at communicado AGLT2]$ globus-url-copy
> file:///home/lixi/osg/swifttest/AGLT2/currenttime.tmp
> gsiftp://gate01.aglt2.org/atlas/data08/OSG/APP/osglixi/
> error: globus_ftp_client: the server responded with an error
> 530 530-Login incorrect. :
> globus_i_gfs_data.c:globus_l_gfs_data_authorize:1050:
> 530-Mapped user 'osg' is invalid.
> 530 End.
Your account there seems messed up.
> [lixi at communicado AGLT2]$ globusrun-ws -submit -F
> gate01.aglt2.org:9443 -c /bin/hostname
> Submitting job...Done.
> Job ID: uuid:b7d614b8-55ac-11dd-b2fe-001a64784960
> Termination time: 07/20/2008 16:06 GMT
> Current job state: Failed
> Destroying job...Done.
> globusrun-ws: Job failed: Error code: 201
> Script stderr:
> /usr/bin/sudo: uid 825675 does not exist in the passwd file!
Again, your account seems broken. Did this ever work for you?
> Thanks,
> Xi
More information about the Swift-user mailing list
