[Swift-user] Re: GT4
lixi at uchicago.edu
Sat Jul 19 11:10:36 CDT 2008
>For GRAM4 on that machine you need (by the looks of it) to
use tcp port
>9443, not the default 8443 which is running some other
services. I think
>this will in general be true for all OSG resources.
How to change it? Does it like this:
<pool handle="AGLT2">
<gridftp url="gsiftp://gate01.aglt2.org" />
<execution provider="gt4" jobmanager="CONDOR"
url="gate01.aglt2.org:9443" />
<workdirectory >/atlas/data08/OSG/DATA</workdirectory>
</pool>
>You could try the above two commands yourself and see what
you get.
[lixi at communicado AGLT2]$ globus-url-copy
file:///home/lixi/osg/swifttest/AGLT2/currenttime.tmp
gsiftp://gate01.aglt2.org/atlas/data08/OSG/APP/osglixi/
error: globus_ftp_client: the server responded with an error
530 530-Login incorrect. :
globus_i_gfs_data.c:globus_l_gfs_data_authorize:1050:
530-Mapped user 'osg' is invalid.
530 End.
[lixi at communicado AGLT2]$ globusrun-ws -submit -F
gate01.aglt2.org:9443 -c /bin/hostname
Submitting job...Done.
Job ID: uuid:b7d614b8-55ac-11dd-b2fe-001a64784960
Termination time: 07/20/2008 16:06 GMT
Current job state: Failed
Destroying job...Done.
globusrun-ws: Job failed: Error code: 201
Script stderr:
/usr/bin/sudo: uid 825675 does not exist in the passwd file!
Xi
More information about the Swift-user
