[Swift-user] Re: GT4
Mihael Hategan hategan at mcs.anl.gov
Sat Jul 19 10:49:10 CDT 2008
On Sat, 2008-07-19 at 10:39 -0500, lixi at uchicago.edu wrote:
> >Can you send logs?
> I run it again with swift-debugger, it seems hanging up. I
> just let it be. The log file is:
> /home/lixi/osg/swifttest/AGLT2/first-20080719-1032-
> h40vbfc8.log
Did you manually stop swift there?
Btw, this seems to be the problem:
2008-07-19 10:32:04,845-0500 DEBUG TaskImpl Task(type=FILE_OPERATION,
identity=urn:0-1-1216481524364) setting status to Failed org.glo
bus.cog.abstraction.impl.file.IrrecoverableResourceException: Error
communicating with the GridFTP server
So it has nothing to do with GRAM.
> Thanks,
> Xi
More information about the Swift-user mailing list
