[Swift-user] suggestion for program flow control
Ben Clifford benc at hawaga.org.uk
Tue Jul 8 01:59:45 CDT 2008
On Tue, 17 Jun 2008, Ben Clifford wrote:
> > I can definitely see the benefit of having separate pipelines for
> > non-dependent parts within the same script, but perhaps there is a way
> > to chain dependent functions that is not dependent on files produced by
> > previous functions?
> I've been playing with some code to do that as someone else requested it.
> Basically you will be able to have a swiftscript variable that expresses
> the dependency, but doesn't have any actual content (such as a file).
> Hopefully later this week there will be something in SVN.
Somewhat later than I'd hoped. Swift SVN r2095 has 'extern' types. You can
use like this:
(external o) a() {
    app {
        helperA @strcat(@arg("dir"),"/restart-extern.1.out") "/etc/group"
"qux";
b(external o) {
    app {
        helperB @strcat(@arg("dir"),"/restart-extern.2.out") "/etc/group"
"baz";
external sync;
sync=a();
b(sync);
This makes a dependency between a and b, but doesn't actually move any
data around; its entirely up to you to ensure that when the a procedure
finishes your data is in the right place for b to find it.
More information about the Swift-user mailing list
