[Swift-user] Passing hostType for MPI jobs
Ben Clifford
benc at hawaga.org.uk
Thu Jul 3 03:34:18 CDT 2008
On Wed, 2 Jul 2008, Andriy Fedorov wrote:
> Ok, I tried that. It indeed allocates correct number of the requested
> hosts. But, there's still a problem. It appears that only one instance
> of the executable is running, at least when I specify jpbType to mpi.
> I am not sure it is being run as an MPI job.
I can replicate that with plain GRAM4 on TG UC. In the PBS Epilogue, I
see:
Limits: nodes=5:ia64-compute:ppn=1,walltime=00:15:00
Nodes: tg-c053 tg-c034 tg-c020 tg-c011 tg-c007
but my code only has COMM_WORLD size 1.
This code doesn't run at all if it is not run through mpi, so I think the
code *is* being run as an mpi job but the mpi node count is not getting
specified correctly.
My present recommended way of doing mpi in Swift is not using jobtype=mpi
in gram, though, so I don't want to spend too much time figuring this out.
The gram-user at globus.org list and/or help at teragrid.org probably can offer
more.
> By the way, I also discovered, that sometimes the order of tags in
> .xml makes difference (meaning, with certain order of "count",
> "walltime" and "hostCount" globusrun-ws will abort). I had no idea
> order matters...
yes.
Those options are defined with an XML Schema <sequence> which means, to be
valid, they must appear in the order they are defined in:
http://www.globus.org/toolkit/docs/4.0/execution/wsgram/schemas/gram_job_description.html#type_JobDescriptionType
More information about the Swift-user
