[Swift-user] Help: Error in Swift: Exitcode file not found 5 queue polls after the job was reported done
Quan Tran Pham
quanpt at cs.uchicago.edu
Thu Jan 31 16:46:28 CST 2008
The directory "~/.globus/scripts" exists, but it is empty.
I try a hello world swift which use echo only, so I use the default
tc.data. The content of sites.xml is like this:
<pool handle="localhost" sysinfo="INTEL32::LINUX">
<gridftp url="local://localhost" storage="/var/tmp" major="1"
minor="0" patch="0" />
<execution provider="pbs" url="none" />
<workdirectory >/var/tmp</workdirectory>
</pool>
And that's all about the environment.
Quan Pham
Mihael Hategan wrote:
> So I can't reproduce this with the latest Swift. Can you tell me if you
> have the ~/.globus/scripts directory on tp-login and what's in it?
> Mihael
> On Wed, 2008-01-30 at 17:16 -0600, Quan Tran Pham wrote:
>> Mihael, this is my first try using PBS, and I got into that error. I
>> use swift version 0.3.
>> Is there any document about using swift with PBS, other than this
>> http://www.ci.uchicago.edu/swift/guides/userguide.php#providers ?
>> Thank you
>> Quan Pham
>> On Jan 30, 2008 3:10 PM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
>> Ok. I'll try to test it. What version of swift? And do you get
>> this on
>> every job, or just occasionally?
>> On Wed, 2008-01-30 at 15:00 -0600, Quan Tran Pham wrote:
>> > I use PBS on teraport tp-login machine, I guess I should you
>> the same
>> > shared file system with everyone.
>> > Quan Pham
>> > On Jan 30, 2008 2:31 PM, Mihael Hategan
>> > So this is specific to the local PBS provider. It
>> may indicate
>> > a problem
>> > with the shared filesystem, but I'll need more
>> details of the
>> > environment you're trying this on.
>> > Mihael
More information about the Swift-user
