[Swift-user] Help: Error in Swift: Exitcode file not found 5 queue polls after the job was reported done
Ben Clifford benc at hawaga.org.uk
Wed Jan 30 14:34:45 CST 2008
The error message seems familiar to me. I think that the one time I played
with the PBS provider a bit I encountered it, but then didn't see anything
immediately obvious to fix and then went to work on other stuff.
On Wed, 30 Jan 2008, Mihael Hategan wrote:
> So this is specific to the local PBS provider. It may indicate a problem
> with the shared filesystem, but I'll need more details of the
> environment you're trying this on.
> Mihael
> On Wed, 2008-01-30 at 12:43 -0600, Quan Tran Pham wrote:
> > Hi everyone,
> > Could someone please help me with this swift problem, or can you point
> > me to where I should get more information?
> > I encountered this message: "Exitcode file not found 5 queue polls
> > after the job was reported done" when trying to run a simple Hello
> > World swift script on PBS.
> > I have attached the log file from swift.
> > Thank you very much
> > Regards
> > Quan Tran Pham
> > _______________________________________________
> > Swift-user mailing list
> > Swift-user at ci.uchicago.edu
> > http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
More information about the Swift-user mailing list
