[Swift-user] Error: "Missing -if argument"
Quan Tran Pham quanpt at cs.uchicago.edu
Fri Feb 22 11:45:02 CST 2008
This time, the error from swift command is "Caused by:
        No status file was found. Check the shared filesystem on localhost"
But you can still find the "Missing -if argument" in the log file.
Thanks
Quan Pham
On Fri, Feb 22, 2008 at 10:18 AM, Ben Clifford <benc at hawaga.org.uk> wrote:
> On Fri, 22 Feb 2008, Mihael Hategan wrote:
> > The wrapper seems to be the one reporting it. -if is the list of input
> > files.
> Right, I know that much...
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20080222/bf37f025/attachment.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20080222/bf37f025/attachment.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20080222/bf37f025/attachment-0001.obj>
More information about the Swift-user mailing list
