[Swift-user] Error: "Missing -if argument"
Quan Tran Pham
quanpt at cs.uchicago.edu
Fri Feb 22 09:07:28 CST 2008
Hi Ben,
Instead of this
outputfile ofiles[]<simple_mapper;prefix="out",suffix=".txt">;
foreach file,i in files {
ofiles[i]=fileWc(file);
I use this foreach loop which works correctly for me (but I don't get the
output array, only one at a time, still ok anyways)
foreach f in files {
countfile c<regexp_mapper;source=@f,match="(.*)",transform="\1.sort">;
c = fileWc(f);
I am using the 2nd loop, hence I don't have the log for previous one. I can
recreate if you need?
About csplit, yes, variable number of files, not only 99 as in my example. I
think I can use Mike's suggestion: wrap csplit with an ls, get the output
and load into another mapper. That should work.
Thank you very much
Regards
Quan Pham
On Fri, Feb 22, 2008 at 6:14 AM, Ben Clifford <benc at hawaga.org.uk> wrote:
> On Thu, 21 Feb 2008, Quan Tran Pham wrote:
> > My simple wc swift script is below, and I keep getting the error:
> "Missing
> > -if argument", can anyone help me with that?
> Have you successfully run any other SwiftScripts with the same
> install/version and on the same site?
> What version are you using?
> Are you running locally or sending to a remote site?
> What do you see from ls -l ./data/
> Please send a log file from such a run.
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20080222/279bfa5c/attachment.html>
More information about the Swift-user
