[Swift-user] Swift running errors
lixi at uchicago.edu
Wed Feb 20 09:58:56 CST 2008
>> Failed to transfer kickstart records from workflowtest-
>> 20080219-1447-1hztqje9/kickstart/8/CIT_CMS_T2Exception in
>> getFile
>Sometimes this happens because there was an error running
you job for some
>other reason (so the job didn't run, a kickstart record
wasn't generated
>and it couldn't be transfered). Have a look in the log file
for an error
>earlier than that (or put the log files online some so I
can look).
This log file is in terminable.ci.uchicago.edu:
/home/lixi/swift/test/newtest/1000nodes/remote/workflowtest-
20080219-1447-1hztqje9.log
>> 2. When runing a workflow which involves 1000nodes, I
>> encounter the following errors very frequently, but not
all
>> the time:
>> java.io.IOException: Too many open files
>What machine are you running on? Have you changed any
configuration
>parameters? A basic 1000 job workflow should run fine with
the default
>settings.
>On the machine you are running on, type ulimit -a and
paste that here.
Yesterday I was running that on login.ci.uchicago.edu, but
it crashed last night, so I tried ulimit -a on
terminable.ci.uchicago.edu and got:
[lixi at terminable ~]$ ulimit -a
core file size (blocks, -c) 0
data seg size (kbytes, -d) unlimited
file size (blocks, -f) unlimited
pending signals (-i) 1024
max locked memory (kbytes, -l) 32
max memory size (kbytes, -m) unlimited
open files (-n) 1024
pipe size (512 bytes, -p) 8
POSIX message queues (bytes, -q) 819200
stack size (kbytes, -s) 10240
cpu time (seconds, -t) unlimited
max user processes (-u) 15871
virtual memory (kbytes, -v) unlimited
Does it mean that I can only at most open 1024 files at one
time?
Xi
More information about the Swift-user
