[Swift-user] Re: build swift
Mihael Hategan hategan at mcs.anl.gov
Tue Feb 12 18:02:46 CST 2008
Sorry. Try now.
On Tue, 2008-02-12 at 16:57 -0600, Zhao Zhang wrote:
> Hi, All
> Here is the error log file when I tried to build swift. Anyone could
> help this?
> To Mihael
> This is the latest log file.
> zhao
> Ioan Raicu wrote:
> > Zhao,
> > You might want to send emails with these kinds of questions to the
> > swift-user mailing, as there are others (i.e. Ben) that could answer.
> > Ioan
> > Zhao Zhang wrote:
> >> Hi, Mihael
> >> could you help me on this?
> >> zhao
> >> Zhao Zhang wrote:
> >>> Hi, Ioan
> >>> When I run falkon-build-swift.sh, I got this problem. See the
> >>> attachment for log file.
> >>> zhao
> >>> Ioan Raicu wrote:
> >>>> cd .../falkon/
> >>>> source falkon.env
> >>>> falkon-checkout-cog.sh      falkon-checkout-swift.sh
> >>>> falkon-checkout-provider.sh falkon-build-swift.s
> >>>> falkon-build-provider.sh
> >>>> viper:/home/iraicu/yongzh/sites-uc-64.xml
> >>>> viper:/home/iraicu/yongzh/tc-uc.data
> plain text document attachment (err.txt)
> zzhang at login1.surveyor:~/falkon> falkon-build-swift.sh
> Buildfile: build.xml
>   [taskdef] Could not load definitions from resource checkstyletask.properties. It could not be found.
> clean:
> clean:
> clean:
>      [echo] [all]: CLEAN
> clean.dependencies:
> dependencies:
> create.dependency.log:
> delete.dependency.log.1:
> deps:
> dep:
> dep.1:
> clean:
> clean:
>      [echo] [abstraction]: CLEAN
> clean.dependencies:
> dependencies:
> deps:
> dep:
> dep.1:
> clean:
> clean:
>      [echo] [abstraction-common]: CLEAN
> clean.dependencies:
> dependencies:
> deps:
> dep:
> dep.1:
> clean:
> clean:
>      [echo] [jglobus]: CLEAN
> clean.dependencies:
> dependencies:
> deps:
> dep:
> dep.1:
> clean:
> clean:
>      [echo] [util]: CLEAN
> clean.dependencies:
> dependencies:
> deps:
> dep:
> dep.1:
> clean:
> clean:
>      [echo] [provider-gt2]: CLEAN
> clean.dependencies:
> dependencies:
> deps:
> dep:
> dep.1:
> dep:
> dep.1:
> dep:
> dep.1:
> dep:
> dep.1:
> BUILD FAILED
> /gpfs/home/zzhang/cog/build.xml:92: The following error occurred while executing this line:
> /gpfs/home/zzhang/cog/modules/all/build.xml:74: The following error occurred while executing this line:
> /gpfs/home/zzhang/cog/mbuild.xml:312: The following error occurred while executing this line:
> /gpfs/home/zzhang/cog/mbuild.xml:316: The following error occurred while executing this line:
> /gpfs/home/zzhang/cog/mbuild.xml:51: The following error occurred while executing this line:
> /gpfs/home/zzhang/cog/modules/all/dependencies.xml:4: The following error occurred while executing this line:
> /gpfs/home/zzhang/cog/mbuild.xml:162: The following error occurred while executing this line:
> /gpfs/home/zzhang/cog/mbuild.xml:167: The following error occurred while executing this line:
> /gpfs/home/zzhang/cog/modules/abstraction/build.xml:77: The following error occurred while executing this line:
> /gpfs/home/zzhang/cog/modules/abstraction/dependencies.xml:10: The following error occurred while executing this line:
> /gpfs/home/zzhang/cog/mbuild.xml:167: Basedir /gpfs/home/zzhang/cog/modules/provider-gt2ft does not exist
> Total time: 2 seconds
> dist:
> dist:
> dist:
>     [mkdir] Created dir: /gpfs/home/zzhang/cog/dist/cog-4_1_6_dev
>     [mkdir] Created dir: /gpfs/home/zzhang/cog/dist/cog-4_1_6_dev/lib
>     [mkdir] Created dir: /gpfs/home/zzhang/cog/dist/cog-4_1_6_dev/bin
>     [mkdir] Created dir: /gpfs/home/zzhang/cog/dist/cog-4_1_6_dev/etc
> log4j.properties:
> log4j.check.module:
> log4j.properties.init:
>      [copy] Copying 1 file to /gpfs/home/zzhang/cog/dist/cog-4_1_6_dev/etc
> log4j.properties.update:
>    [concat] No existing resources and no nested text, doing nothing
>      [java] Warning: source log (/gpfs/home/zzhang/cog/modules/all/CHANGES.txt) does not exist
> build.dependencies:
> dependencies:
> deps:
> dep:
> dep.1:
> dist:
> dist:
> log4j.properties:
> log4j.check.module:
> build.dependencies:
> dependencies:
> deps:
> dep:
> dep.1:
> dist:
> dist:
> log4j.properties:
> log4j.check.module:
> build.dependencies:
> dependencies:
> deps:
> dep:
> dep.1:
> dist:
> dist:
> log4j.properties:
> log4j.check.module:
>      [java] Warning: source log (/gpfs/home/zzhang/cog/modules/jglobus/../../modules/jglobus/CHANGES.txt) does not exist
> build.dependencies:
> dependencies:
> deps:
>      [echo] [jglobus]: DIST
>      [echo] [jglobus]: JARCOPY
>      [copy] Copying 11 files to /gpfs/home/zzhang/cog/dist/cog-4_1_6_dev/lib
>      [copy] Copying 4 files to /gpfs/home/zzhang/cog/dist/cog-4_1_6_dev/lib
> delete.jar:
>      [echo] [jglobus]: DELETE.JAR (cog-jglobus-dev-080204.jar)
>    [delete] Deleting: /gpfs/home/zzhang/cog/dist/cog-4_1_6_dev/lib/cog-jglobus-dev-080204.jar
> compile:
>      [echo] [jglobus]: COMPILE
>     [mkdir] Created dir: /gpfs/home/zzhang/cog/modules/jglobus/build
> copy.resources:
> jar:
>      [echo] [jglobus]: JAR (cog-jglobus-dev-080204.jar)
>     [mkdir] Created dir: /gpfs/home/zzhang/cog/modules/jglobus/build/etc.tmp
>       [jar] Warning: skipping jar archive /gpfs/home/zzhang/cog/dist/cog-4_1_6_dev/lib/cog-jglobus-dev-080204.jar because no files were included.
>       [jar] Building MANIFEST-only jar: /gpfs/home/zzhang/cog/dist/cog-4_1_6_dev/lib/cog-jglobus-dev-080204.jar
> create:
> launcher:
> create.launcher:
>      [echo] [jglobus]: LAUNCHER grid-proxy-init
>      [copy] Copying 1 file to /gpfs/home/zzhang/cog/dist/cog-4_1_6_dev/bin
> launcher:
> create.launcher:
>      [echo] [jglobus]: LAUNCHER grid-proxy-info
> launcher:
> create.launcher:
>      [echo] [jglobus]: LAUNCHER grid-proxy-destroy
> launcher:
> create.launcher:
>      [echo] [jglobus]: LAUNCHER grid-cert-info
> launcher:
> create.launcher:
>      [echo] [jglobus]: LAUNCHER grid-info-search
> launcher:
> create.launcher:
>      [echo] [jglobus]: LAUNCHER globusrun
> launcher:
> create.launcher:
>      [echo] [jglobus]: LAUNCHER globus-url-copy
> launcher:
> create.launcher:
>      [echo] [jglobus]: LAUNCHER globus-gass-server
> launcher:
> create.launcher:
>      [echo] [jglobus]: LAUNCHER globus-gass-server-shutdown
> launcher:
> create.launcher:
>      [echo] [jglobus]: LAUNCHER globus-personal-gatekeeper
> launcher:
> create.launcher:
>      [echo] [jglobus]: LAUNCHER grid-change-pass-phrase
> launcher:
> create.launcher:
>      [echo] [jglobus]: LAUNCHER cog-myproxy
> launcher:
> create.launcher:
>      [echo] [jglobus]: LAUNCHER globus2jks
> launcher:
> create.launcher:
>      [echo] [jglobus]: LAUNCHER cog-proxy-init
> deploy.examples:
> do.deploy.examples:
>      [copy] Copying 1 file to /gpfs/home/zzhang/cog/dist/cog-4_1_6_dev/lib
> dep:
> dep.1:
> dist:
> dist:
> log4j.properties:
> log4j.check.module:
>      [java] Warning: source log (/gpfs/home/zzhang/cog/modules/util/../../modules/util/CHANGES.txt) does not exist
> build.dependencies:
> dependencies:
> deps:
>      [echo] [util]: DIST
>      [echo] [util]: JARCOPY
> delete.jar:
>      [echo] [util]: DELETE.JAR (cog-util-0.92.jar)
> compile:
>      [echo] [util]: COMPILE
>     [mkdir] Created dir: /gpfs/home/zzhang/cog/modules/util/build
>     [javac] Compiling 47 source files to /gpfs/home/zzhang/cog/modules/util/build
>     [javac] Note: * uses or overrides a deprecated API.
>     [javac] Note: Recompile with -Xlint:deprecation for details.
> copy.resources:
> jar:
>      [echo] [util]: JAR (cog-util-0.92.jar)
>     [mkdir] Created dir: /gpfs/home/zzhang/cog/modules/util/build/etc.tmp
>       [jar] Building jar: /gpfs/home/zzhang/cog/dist/cog-4_1_6_dev/lib/cog-util-0.92.jar
> create:
> launcher:
> create.launcher:
>      [echo] [util]: LAUNCHER cog-register
> deploy.examples:
> do.deploy.examples:
>      [echo] [abstraction-common]: DIST
>      [echo] [abstraction-common]: JARCOPY
> delete.jar:
>      [echo] [abstraction-common]: DELETE.JAR (cog-abstraction-common-2.2.jar)
> compile:
>      [echo] [abstraction-common]: COMPILE
>     [mkdir] Created dir: /gpfs/home/zzhang/cog/modules/abstraction-common/build
>     [javac] Compiling 149 source files to /gpfs/home/zzhang/cog/modules/abstraction-common/build
> copy.resources:
> jar:
>      [echo] [abstraction-common]: JAR (cog-abstraction-common-2.2.jar)
>     [mkdir] Created dir: /gpfs/home/zzhang/cog/modules/abstraction-common/build/etc.tmp
>       [jar] Building jar: /gpfs/home/zzhang/cog/dist/cog-4_1_6_dev/lib/cog-abstraction-common-2.2.jar
> create:
> launcher:
> create.launcher:
>      [echo] [abstraction-common]: LAUNCHER cogrun
> launcher:
> create.launcher:
>      [echo] [abstraction-common]: LAUNCHER cog-job-submit
> launcher:
> create.launcher:
>      [echo] [abstraction-common]: LAUNCHER cog-file-operation
> launcher:
> create.launcher:
>      [echo] [abstraction-common]: LAUNCHER cog-file-transfer
> example.launcher:
> create.example.launcher:
>      [echo] [abstraction-common]: EXAMPLE LAUNCHER examples/hierarchical-queue-handler
>      [copy] Copying 1 file to /gpfs/home/zzhang/cog/dist/cog-4_1_6_dev/bin/examples
> example.launcher:
>      [echo] [abstraction-common]: EXAMPLE LAUNCHER examples/hierarchical-set-handler
> launcher:
> create.launcher:
>      [echo] [abstraction-common]: LAUNCHER cog-task2xml
> example.launcher:
>      [echo] [abstraction-common]: EXAMPLE LAUNCHER examples/taskgraph-2-xml
> launcher:
> create.launcher:
>      [echo] [abstraction-common]: LAUNCHER cog-checkpoint-submit
> launcher:
> create.launcher:
>      [echo] [abstraction-common]: LAUNCHER cog-checkpoint-status
> example.launcher:
>      [echo] [abstraction-common]: EXAMPLE LAUNCHER examples/xml-2-taskgraph
> launcher:
> create.launcher:
>      [echo] [abstraction-common]: LAUNCHER cog-info
> deploy.examples:
> do.deploy.examples:
> dep:
> dep.1:
> dist:
> dist:
> log4j.properties:
> log4j.check.module:
> build.dependencies:
> dependencies:
> deps:
> dep:
> dep.1:
> dep:
> dep.1:
> dep:
> dep.1:
>      [echo] [provider-gt2]: DIST
>      [echo] [provider-gt2]: JARCOPY
> delete.jar:
>      [echo] [provider-gt2]: DELETE.JAR (cog-provider-gt2-2.3.jar)
> compile:
>      [echo] [provider-gt2]: COMPILE
>     [mkdir] Created dir: /gpfs/home/zzhang/cog/modules/provider-gt2/build
>     [javac] Compiling 21 source files to /gpfs/home/zzhang/cog/modules/provider-gt2/build
>     [javac] Note: /gpfs/home/zzhang/cog/modules/provider-gt2/src/org/globus/cog/abstraction/impl/file/ftp/CredentialsDialog.java uses or overrides a deprecated API.
> copy.resources:
>      [copy] Copying 1 file to /gpfs/home/zzhang/cog/modules/provider-gt2/build
> update.provider.props:
> jar:
>      [echo] [provider-gt2]: JAR (cog-provider-gt2-2.3.jar)
>     [mkdir] Created dir: /gpfs/home/zzhang/cog/modules/provider-gt2/build/etc.tmp
>       [jar] Building jar: /gpfs/home/zzhang/cog/dist/cog-4_1_6_dev/lib/cog-provider-gt2-2.3.jar
> create:
> deploy.examples:
> do.deploy.examples:
> dep:
> dep.1:
> BUILD FAILED
> /gpfs/home/zzhang/cog/build.xml:81: The following error occurred while executing this line:
> /gpfs/home/zzhang/cog/modules/all/build.xml:57: The following error occurred while executing this line:
> /gpfs/home/zzhang/cog/mbuild.xml:442: The following error occurred while executing this line:
> /gpfs/home/zzhang/cog/mbuild.xml:78: The following error occurred while executing this line:
> /gpfs/home/zzhang/cog/modules/abstraction/build.xml:58: The following error occurred while executing this line:
> Total time: 31 seconds
> cleanGenerated:
> distclean:
> clean:
>      [echo] [vdsk]: CLEAN
> clean.dependencies:
> dependencies:
>    [delete] Deleting: /gpfs/home/zzhang/cog/dependency.log.clean
> deps:
> dep:
> dep.1:
> clean:
> clean:
>      [echo] [karajan]: CLEAN
> clean.dependencies:
> dependencies:
> deps:
> dep:
> dep.1:
> clean:
> clean:
> clean.dependencies:
> dependencies:
> deps:
> dep:
> dep.1:
> clean:
> clean:
>    [delete] Deleting directory /gpfs/home/zzhang/cog/modules/abstraction-common/build
> clean.dependencies:
> dependencies:
> deps:
> dep:
> dep.1:
> clean:
> clean:
>    [delete] Deleting directory /gpfs/home/zzhang/cog/modules/jglobus/build
> clean.dependencies:
> dependencies:
> deps:
> dep:
> dep.1:
> clean:
> clean:
>    [delete] Deleting directory /gpfs/home/zzhang/cog/modules/util/build
> clean.dependencies:
> dependencies:
> deps:
> dep:
> dep.1:
> clean:
> clean:
>    [delete] Deleting directory /gpfs/home/zzhang/cog/modules/provider-gt2/build
> clean.dependencies:
> dependencies:
> deps:
> dep:
> dep.1:
> dep:
> dep.1:
> dep:
> dep.1:
> dep:
> dep.1:
> BUILD FAILED
> /gpfs/home/zzhang/cog/modules/vdsk/build.xml:189: The following error occurred while executing this line:
> /gpfs/home/zzhang/cog/modules/vdsk/dependencies.xml:4: The following error occurred while executing this line:
> /gpfs/home/zzhang/cog/modules/karajan/build.xml:78: The following error occurred while executing this line:
> /gpfs/home/zzhang/cog/modules/karajan/dependencies.xml:4: The following error occurred while executing this line:
> generateVersion:
> antlr:
>      [java] ANTLR Parser Generator   Version 2.7.5 (20050128)   1989-2005 jGuru.com
>      [java] resources/swiftscript.g:936: warning:nondeterminism upon
>      [java] resources/swiftscript.g:936:     k==1:LBRACK
>      [java] resources/swiftscript.g:936:     k==2:ID,STRING_LITERAL,LBRACK,LPAREN,AT,PLUS,MINUS,STAR,NOT,INT_LITERAL,FLOAT_LITERAL,"true","false","null"
>      [java] resources/swiftscript.g:936:     between alt 1 and exit branch of block
> compileSchema:
>      [java] Time to build schema type system: 1.676 seconds
>      [java] Time to generate code: 0.494 seconds
>      [java] Time to compile code: 5.0 seconds
>      [java] Compiled types to: /gpfs/home/zzhang/cog/modules/vdsk/../../modules/vdsk/lib/vdldefinitions.jar
> dist:
> dist:
>     [mkdir] Created dir: /gpfs/home/zzhang/cog/modules/vdsk/dist/vdsk-0.3-dev
>     [mkdir] Created dir: /gpfs/home/zzhang/cog/modules/vdsk/dist/vdsk-0.3-dev/lib
>     [mkdir] Created dir: /gpfs/home/zzhang/cog/modules/vdsk/dist/vdsk-0.3-dev/bin
>     [mkdir] Created dir: /gpfs/home/zzhang/cog/modules/vdsk/dist/vdsk-0.3-dev/etc
> log4j.properties:
> log4j.check.module:
>      [copy] Copying 1 file to /gpfs/home/zzhang/cog/modules/vdsk/dist/vdsk-0.3-dev/etc
> build.dependencies:
> dependencies:
>    [delete] Deleting: /gpfs/home/zzhang/cog/dependency.log.dist
> deps:
> dep:
> dep.1:
> dist:
> dist:
> log4j.properties:
> log4j.check.module:
> build.dependencies:
> dependencies:
> deps:
> dep:
> dep.1:
> dist:
> dist:
> log4j.properties:
> log4j.check.module:
> build.dependencies:
> dependencies:
> deps:
> dep:
> dep.1:
> dist:
> dist:
> log4j.properties:
> log4j.check.module:
> build.dependencies:
> dependencies:
> deps:
> dep:
> dep.1:
> dist:
> dist:
> log4j.properties:
> log4j.check.module:
> build.dependencies:
> dependencies:
> deps:
>      [copy] Copying 11 files to /gpfs/home/zzhang/cog/modules/vdsk/dist/vdsk-0.3-dev/lib
>      [copy] Copying 4 files to /gpfs/home/zzhang/cog/modules/vdsk/dist/vdsk-0.3-dev/lib
> delete.jar:
>    [delete] Deleting: /gpfs/home/zzhang/cog/modules/vdsk/dist/vdsk-0.3-dev/lib/cog-jglobus-dev-080204.jar
> compile:
> copy.resources:
> jar:
>       [jar] Warning: skipping jar archive /gpfs/home/zzhang/cog/modules/vdsk/dist/vdsk-0.3-dev/lib/cog-jglobus-dev-080204.jar because no files were included.
>       [jar] Building MANIFEST-only jar: /gpfs/home/zzhang/cog/modules/vdsk/dist/vdsk-0.3-dev/lib/cog-jglobus-dev-080204.jar
> create:
> launcher:
> create.launcher:
>      [copy] Copying 1 file to /gpfs/home/zzhang/cog/modules/vdsk/dist/vdsk-0.3-dev/bin
> launcher:
> create.launcher:
> launcher:
> create.launcher:
> launcher:
> create.launcher:
> launcher:
> create.launcher:
> launcher:
> create.launcher:
> launcher:
> create.launcher:
> launcher:
> create.launcher:
> launcher:
> create.launcher:
> launcher:
> create.launcher:
> launcher:
> create.launcher:
> launcher:
> create.launcher:
> launcher:
> create.launcher:
> launcher:
> create.launcher:
> deploy.examples:
> do.deploy.examples:
>      [copy] Copying 1 file to /gpfs/home/zzhang/cog/modules/vdsk/dist/vdsk-0.3-dev/lib
> dep:
> dep.1:
> dist:
> dist:
> log4j.properties:
> log4j.check.module:
> build.dependencies:
> dependencies:
> deps:
>      [echo] [util]: DIST
> delete.jar:
> compile:
> copy.resources:
> jar:
>       [jar] Building jar: /gpfs/home/zzhang/cog/modules/vdsk/dist/vdsk-0.3-dev/lib/cog-util-0.92.jar
> create:
> launcher:
> create.launcher:
> deploy.examples:
> do.deploy.examples:
> delete.jar:
> compile:
> copy.resources:
> jar:
>       [jar] Building jar: /gpfs/home/zzhang/cog/modules/vdsk/dist/vdsk-0.3-dev/lib/cog-abstraction-common-2.2.jar
> create:
> launcher:
> create.launcher:
> launcher:
> create.launcher:
> launcher:
> create.launcher:
> launcher:
> create.launcher:
> example.launcher:
>      [copy] Copying 1 file to /gpfs/home/zzhang/cog/modules/vdsk/dist/vdsk-0.3-dev/bin/examples
> example.launcher:
> launcher:
> create.launcher:
> example.launcher:
> launcher:
> create.launcher:
> launcher:
> create.launcher:
> example.launcher:
> launcher:
> create.launcher:
> deploy.examples:
> do.deploy.examples:
> dep:
> dep.1:
> dist:
> dist:
> log4j.properties:
> log4j.check.module:
> build.dependencies:
> dependencies:
> deps:
> dep:
> dep.1:
> dep:
> dep.1:
> dep:
> dep.1:
> delete.jar:
> compile:
> copy.resources:
> jar:
>       [jar] Building jar: /gpfs/home/zzhang/cog/modules/vdsk/dist/vdsk-0.3-dev/lib/cog-provider-gt2-2.3.jar
> create:
> deploy.examples:
> do.deploy.examples:
> dep:
> dep.1:
> BUILD FAILED
> /gpfs/home/zzhang/cog/modules/vdsk/build.xml:73: The following error occurred while executing this line:
> /gpfs/home/zzhang/cog/modules/karajan/build.xml:59: The following error occurred while executing this line:
> Total time: 34 seconds
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
More information about the Swift-user mailing list
