[Swift-user] Re: r1609 run
Mihael Hategan
hategan at mcs.anl.gov
Tue Feb 5 22:12:09 CST 2008
Actually I take that back. However, it does look like a project problem.
Are you sure you're using the right one?
On Tue, 2008-02-05 at 22:08 -0600, Mihael Hategan wrote:
> Ok, so it looks like through the WS-GRAM route the project attribute
> gets lost somewhere.
> So until that gets fixed, you can probably try logging in to the head
> node and setting a default project.
> Mihael
> On Tue, 2008-02-05 at 21:51 -0600, Mihael Hategan wrote:
> > Actually now that I think of it swift tries to run /bin/bash which runs
> > wrapper.sh which in turns runs the actual executable. So it's a
> > different problem.
> > On Tue, 2008-02-05 at 18:40 -0800, Mike Kubal wrote:
> > > UC-64 amberize_ligand
> > > /home/kubal/MD_tools/amberize_ligand INSTALLED
> > > INTEL64::LINUX
> > > ENV::ACHOME=/home/kubal/dock6/bin/antechamber;ENV::DOCK_HOME="/home/kubal/dock6";ENV::PATH="/home/kubal/dock6/bin:/usr/bin:/bin";GLOBUS::host_types=ia64-compute
> > > --- Ben Clifford <benc at hawaga.org.uk> wrote:
> > > > can you send the tc.data entry that you think is
> > > > being used for this
> > > > executable?
> > > > _______________________________________________
> > > > Swift-user mailing list
> > > > Swift-user at ci.uchicago.edu
> > > http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
> > > ____________________________________________________________________________________
> > > Be a better friend, newshound, and
> > > know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
More information about the Swift-user
