[Swift-user] kickstart.xml transfer error
lixi at uchicago.edu
Sat Feb 2 14:37:05 CST 2008
When running a swift program with kickstart file transfer
turned on (kickstart.always.transfer=true), I encounter the
following errors:
node completed
node completed
Failed to transfer kickstart records from workflowtest-
20080202-1406-sf494p62/kickstart/o/BNL_ATLAS_2Exception in
getFile
task:transfer @ vdl-int.k, line: 322
sys:try @ vdl-int.k, line: 322
vdl:transferkickstartrec @ vdl-int.k, line: 409
sys:set @ vdl-int.k, line: 409
sys:sequential @ vdl-int.k, line: 409
sys:try @ vdl-int.k, line: 408
sys:else @ vdl-int.k, line: 407
sys:if @ vdl-int.k, line: 405
sys:set @ vdl-int.k, line: 404
sys:catch @ vdl-int.k, line: 396
sys:try @ vdl-int.k, line: 354
task:allocatehost @ vdl-int.k, line: 334
vdl:execute2 @ execute-default.k, line: 23
sys:restartonerror @ execute-default.k, line: 21
sys:sequential @ execute-default.k, line: 19
sys:try @ execute-default.k, line: 18
sys:if @ execute-default.k, line: 17
sys:then @ execute-default.k, line: 16
sys:if @ execute-default.k, line: 15
vdl:execute @ workflowtest.kml, line: 31
worknode @ workflowtest.kml, line: 105
sys:sequential @ workflowtest.kml, line: 104
sys:parallelfor @ workflowtest.kml, line: 88
sys:sequential @ workflowtest.kml, line: 87
sys:parallel @ workflowtest.kml, line: 77
vdl:mainp @ workflowtest.kml, line: 76
mainp @ vdl.k, line: 150
vdl:mains @ workflowtest.kml, line: 75
rlog:restartlog @ workflowtest.kml, line: 74
kernel:project @ workflowtest.kml, line: 2
workflowtest-20080202-1406-sf494p62
Caused by:
org.globus.cog.abstraction.impl.file.FileResourceException:
Exception in getFile
Caused by: org.globus.ftp.exception.ServerException: Server
refused performing the request. Custom message: (error code
1) [Nested exception message: Custom message: Unexpected
reply: 500-Command failed. :
globus_gridftp_server_file.c:globus_l_gfs_file_send:2190:
500-globus_l_gfs_file_open failed.
500-globus_gridftp_server_file.c:globus_l_gfs_file_open:1694:
500-globus_xio_register_open failed.
500-globus_xio_file_driver.c:globus_l_xio_file_open:438:
500-Unable to open
file /usatlas/prodjob/share/lixi/workflowtest-20080202-1406-
sf494p62/kickstart/o/node-o2l4duni-kickstart.xml
500-globus_xio_file_driver.c:globus_l_xio_file_open:381:
500-System error in open: No such file or directory
500-globus_xio: A system call failed: No such file or
directory
500 End.] [Nested exception is
org.globus.ftp.exception.UnexpectedReplyCodeException:
Custom message: Unexpected reply: 500-Command failed. :
500-Unable to open
directory
500 End.]
node completed
node completed
But finally, I can still get the kickstart.xml files under
my directory where issued the swift command.
Could you tell me why I encountered such errors and how to
fix them?
Thanks a lot!
Xi
More information about the Swift-user
