[Swift-user] Node specification for local PBS/Torque provider
Andriy Fedorov
fedorov at cs.wm.edu
Fri Aug 15 07:51:38 CDT 2008
Michael,
thank you for reply. I looked through the cog source, qsub scripts it
generates, and I think I localized the problem.
> You should file a bug report with cog
> (http://bugzilla.mcs.anl.gov/globus/enter_bug.cgi?product=CoG%20Kit) (so
> that I don't forget about it) and it will get fixed eventually.
I logged the bug.
> The exact timing depends on how badly you need it.
Well, I am not sure what you mean by this... I certainly did not find
this bug having nothing to do and browsing through the CoG code. I
tried to accomplish something, and now I am blocked because of this
bug.
If it takes too long, I guess I will have to fix it myself. I don't
know how to rush a bug fix. I know you guys are very busy and have
your own priorities...
Andrey Fedorov
Center for Real-Time Computing
College of William and Mary
http://www.cs.wm.edu/~fedorov
On Thu, Aug 14, 2008 at 7:59 PM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> On Thu, 2008-08-14 at 17:16 -0400, Andriy Fedorov wrote:
>> Hi,
>> I was unable to find the details on how nodes should be specified when
>> local PBS provider is used.
> Looking at the code, host_types and host_count don't seem to be handled
> by the pbs provider.
> that I don't forget about it) and it will get fixed eventually. The
> Mihael
More information about the Swift-user
