[Swift-user] Re: swift script calling procedure
Ben Clifford benc at hawaga.org.uk
Fri Aug 1 02:12:25 CDT 2008
On Thu, 31 Jul 2008, Michael Wilde wrote:
> Perhaps the code he tried was wrong or never worked, or perhaps the case of
> the function or the case checking rules changed between the time this last
> worked and now.
The checking rules are definitely stronger than they were before - this is
likely from Milena's checks.
Whether Swift should be case sensitive on identifiers seems poorly
defined; karajan will take either case, but the XML-related history would
suggest that case should be significiant (specifically a QName is case
sensitive).
I'm not terribly fussed either way (though I'd probably go for case
sensitivity to be more C/Java-like) but I think it would be good to be
defined more than as accidents of the compile-time and runtime layer.
More information about the Swift-user mailing list
