[Swift-user] sites.xml entry for Abe teragrd site
Michael Wilde
wilde at mcs.anl.gov
Mon Apr 14 14:39:39 CDT 2008
Mike, I think this is pretty close to what you need, but I did not test it:
<pool handle="abe" sysinfo="INTEL32::LINUX">
<gridftp url="gsiftp://grid-abe.ncsa.teragrid.org"/>
<jobmanager universe="vanilla"
url="grid-abe.ncsa.teragrid.org/jobmanager-pbs" major="2"/>
<workdirectory>/cfs/scratch/users/mkubal/swiftwork</workdirectory>
-or-
<workdirectory>/u/ac/mkubal/swiftwork</workdirectory>
- be sure to create these swiftwork dirs first!
</pool>
What you should do:
create the swiftwork dirs listed above
first is for large scratch space,
second is for your persistent user space
remove the -comments- above and use only one workdirectory.
I think you can use mainly the scratch one for now
test submitting a simple command via globus-job-run (first to the
default for jobmanger, then to jobmanager-pbs)
test copying a short file to the work dirs using globus-url copy
then try a simple workflow
Ben, Sarah or Mihael may be able to help you find out if WS-GRAM is
available and working on Abe. If so, you should switch to that to avoid
overrunning Abe's gatekeeper. And use the throttling properties that you
and Ben worked out.
- Mike
More information about the Swift-user
