[Swift-user] Success with fork, but exception in getFile with	condor
    Anand Padmanabhan
    anand-padmanabhan-1 at uiowa.edu
    Mon Sep 17 15:09:37 CDT 2007
>>>  Also I know some condor systems, job executables get dumped a
>>> temporary directory on a worker node's local file system. Would this
>>> have any effect on Swift?
>> As long as Condor/the job manager honor the directory rls setting, this
>> shouldn't make any difference.
> This is something we need to make sure this is the case. I know we had a
> earlier problem at FNAL_FERMIGRID on which the initial dir globus
> parameter was not respected. You can find details at
> https://twiki.grid.iu.edu/twiki/bin/view/Troubleshooting/NewUserRunningJobsFailureFNAL
I checked with FNAL with 2 of the sites on which Jing was having
problems with. As I suspected the siteadmin confirmed that the two
gatekeepers in question were running NFS-lite and do not respect the RSL
initial directory variable. The lack of support of initialdir on some
OSG sites is known issue and it does break compatibility.
Also, is there a way (some parameter we specify), so that swift not to
set the initialdir parameter. This way the job can finish in what ever
directory it gets dumped to by the batch system and then possibly copy
files over to expected location in the $OSG_DATA directory.
Anand
More information about the Swift-user
