[Swift-user] Error: Attempted to close nonexistent channelbuffers
Mihael Hategan
hategan at mcs.anl.gov
Thu Sep 13 19:31:47 CDT 2007
What Ben said applies. You should not see this error if the workflow is
otherwise correct.
You can also try one of the latest nightly builds.
Mihael
On Thu, 2007-09-13 at 16:24 -0400, Allen, M. David wrote:
> I'm using vdsk-0.2, downloaded yesterday.
> -----Original Message-----
> From: Mihael Hategan [mailto:hategan at mcs.anl.gov]
> Sent: Thursday, September 13, 2007 4:22 PM
> To: Allen, M. David
> Cc: swift-user at ci.uchicago.edu
> Subject: Re: [Swift-user] Error: Attempted to close nonexistent
> channelbuffers
> What version are you using?
> That error shows a bug in the Swift implementation, and it should have
> been fixed, at least in SVN.
> Mihael
> On Thu, 2007-09-13 at 14:36 -0400, Allen, M. David wrote:
> > Hello,
> > I'm just getting started with Swift, and trying to program a fairly
> > trivial sample to get started.
> > My swiftscript fails with the message:
> > "Execution failed:
> > grep started
> > Attempted to close nonexistent channel buffers"
> > Can anyone point me to the documentation that describes such errors?
> > This is referring to a spot in my code that is executing a very
> > vanilla grep operation. My input file is just 14 lines long, and
> this
> > error consistently happens towards the end of the overall workflow
> > execution.
> > The code:
> > type blog {
> > string name;
> > string feedURL;
> > type file { }
> > (file headlines) getHeadlines(blog b) {
> > app {
> > feeder @b.feedURL stdout=@filename(headlines);
> > (file results[]) processBlogs(blog blogs[]) {
> > foreach blog el, index in blogs {
> > results[index] = getHeadlines( el ) ;
> > (string matches) findSingleMatch(file input, string searchTerm) {
> > app {
> > grep "-i" searchTerm @filename(input)
> stdout=@matches;
> > (file matches) findMatches(file inputs[], string searchTerm) {
> > string final;
> > foreach input, index in inputs {
> > string intermed = findSingleMatch(input, searchTerm);
> > final = strcat(final, intermed);
> > matches = dumpString(final);
> > (int retVal) debug(string m) {
> > app {
> > echo m ;
> > (file t) dumpString(string m) {
> > app {
> > echo m stdout=@filename(t);
> > blog blogs[] <csv_mapper; file="blogs.csv", delim=",",
> > header="true">;
> > file output[] <simple_mapper;
> > prefix="output/blogHeadlines",suffix=".txt">;
> > file final <simple_mapper; prefix="output/result", suffix=".txt">;
> > output = processBlogs(blogs);
> > final = findMatches(output, "ARG 0");
> > Any help would be greatly appreciated.
> > M. David Allen
> > _______________________________________________
> > Swift-user mailing list
> > Swift-user at ci.uchicago.edu
> > http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
More information about the Swift-user
