[Swift-user] Error: Attempted to close nonexistent channel buffers
Mihael Hategan
hategan at mcs.anl.gov
Thu Sep 13 15:32:40 CDT 2007
Hmm. Do you have a simple example that triggers it?
On Thu, 2007-09-13 at 15:29 -0500, Veronika Nefedova wrote:
> actually, this error shows up when there is a mismatch between input/
> output lists in declaration and in the function call. I've seen this
> error today - the number of parameters didn't match in declaration
> and actual function call. Once it was fixed, the error went away.
> Nika
> On Sep 13, 2007, at 3:22 PM, Mihael Hategan wrote:
> > What version are you using?
> > That error shows a bug in the Swift implementation, and it should have
> > been fixed, at least in SVN.
> > Mihael
> > On Thu, 2007-09-13 at 14:36 -0400, Allen, M. David wrote:
> >> Hello,
> >> I'm just getting started with Swift, and trying to program a fairly
> >> trivial sample to get started.
> >> My swiftscript fails with the message:
> >> "Execution failed:
> >> grep started
> >> Attempted to close nonexistent channel buffers"
> >> Can anyone point me to the documentation that describes such errors?
> >> This is referring to a spot in my code that is executing a very
> >> vanilla grep operation. My input file is just 14 lines long, and
> >> this
> >> error consistently happens towards the end of the overall workflow
> >> execution.
> >> The code:
> >> type blog {
> >> string name;
> >> string feedURL;
> >> type file { }
> >> (file headlines) getHeadlines(blog b) {
> >> app {
> >> feeder @b.feedURL stdout=@filename(headlines);
> >> (file results[]) processBlogs(blog blogs[]) {
> >> foreach blog el, index in blogs {
> >> results[index] = getHeadlines( el ) ;
> >> (string matches) findSingleMatch(file input, string searchTerm) {
> >> app {
> >> grep "-i" searchTerm @filename(input)
> >> stdout=@matches;
> >> (file matches) findMatches(file inputs[], string searchTerm) {
> >> string final;
> >> foreach input, index in inputs {
> >> string intermed = findSingleMatch(input, searchTerm);
> >> final = strcat(final, intermed);
> >> matches = dumpString(final);
> >> (int retVal) debug(string m) {
> >> app {
> >> echo m ;
> >> (file t) dumpString(string m) {
> >> app {
> >> echo m stdout=@filename(t);
> >> blog blogs[] <csv_mapper; file="blogs.csv", delim=",",
> >> header="true">;
> >> file output[] <simple_mapper;
> >> prefix="output/blogHeadlines",suffix=".txt">;
> >> file final <simple_mapper; prefix="output/result", suffix=".txt">;
> >> output = processBlogs(blogs);
> >> final = findMatches(output, "ARG 0");
> >> Any help would be greatly appreciated.
> >> M. David Allen
> >> _______________________________________________
> >> Swift-user mailing list
> >> Swift-user at ci.uchicago.edu
> >> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
More information about the Swift-user
