[Swift-user] follow up of kickstart executable not found problem
Jing Tie tiejing at gmail.com
Sun Sep 9 12:09:34 CDT 2007
Sure.
On 9/9/07, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> Please post the whole workflow and the whole log.
> On Sun, 2007-09-09 at 11:43 -0500, Jing Tie wrote:
> > Hi,
> > I tried duplicate job again using the latest swift with
> > "log4j.logger.org.globus.cog.abstraction=DEBUG".
> > It didn't generated duplicate-*** directory under simple-wf-***
> > directory. Details:
> > Resource (org.globus.cog.abstraction.impl.file.gridftp.FileResourceImpl at cbc2d3)
> > successfully released
> > Task(type=4, identity=urn:0-0-1189348296362) setting status to Failed
> > Could not set current directory to "null"
> > duplicate failed
> > The following errors have occurred:
> > 1. Could not initialize shared directory on NWICG_NotreDame
> > Caused by:
> > Caused by:
> >         Required argument missing
> > in simple-wf-fc06kzz28d880.log:
> > 2007-09-09 09:31:39,911 DEBUG FileResourceCache Resource
> > 2007-09-09 09:31:39,911 DEBUG TaskImpl Task(type=4,
> > identity=urn:0-0-1189348296362) setting status to Failed Could not set
> > 2007-09-09 09:31:39,938 INFO  vdl:mains Errors detected. Cleanup not done.
> > 2007-09-09 09:31:39,963 DEBUG VDL2ExecutionContext Execution completed
> > with errors
> > Execution completed with errors
> > There is nothing under
> > osg.hpcc.nd.edu/dscratch/osg/data/osg/jtie/simple-wf-fc06kzz28d880
> > except empty shared directory.
> > Thanks,
> > Jing
> > On 9/7/07, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> > > Nevermind that. It's eating the empty stdin argument. This doesn't make
> > > sense. Fork used to behave.
> > > Can you add this to log4j.properties, run again, and post the log?
> > > On Fri, 2007-09-07 at 23:02 -0500, Mihael Hategan wrote:
> > > > Can you post the workflow?
> > > > On Fri, 2007-09-07 at 21:56 -0500, Jing Tie wrote:
> > > > > Thanks!
> > > > > I checked the procedure, and found that the filenames of the output
> > > > > files of "myapp" are the same as "File f". So the first option should
> > > > > not be the problem.
> > > > > Then I tried a very simple swift script that doesn't need R:
> > > > > app function: add some lines to the input file to generate the output file
> > > > > input file name: simpleFile.txt
> > > > > output file name: simpleFile.output
> > > > > application script location: $OSG_APP/osg/jtie/duplicate.sh
> > > > > jobmanager: jobmanager-fork
> > > > > duplicate failed
> > > > > 1. Application "duplicate" failed (Failed to link input file
> > > > > /dscratch/osg/app/osg/jtie/duplicate.sh)
> > > > >         Arguments: "simpleFile.txt"
> > > > >         Host: NWICG_NotreDame
> > > > >         Directory: simple-wf-xgh9e9q1z0af2/duplicate-it7hyvgi
> > > > >         STDERR:
> > > > >         STDOUT:
> > > > > after execution, 3 empty directories (not files, and also weird name)
> > > > > were generated:
> > > > > duplicate-gt7hyvgi-simpleFile.output
> > > > > duplicate-ht7hyvgi-simpleFile.output
> > > > > duplicate-it7hyvgi-simpleFile.output
> > > > > wrapper.log:
> > > > > DIR=duplicate-gt7hyvgi
> > > > > STDOUT=simpleFile.output
> > > > > STDERR=stderr.txt
> > > > > DIRS=simpleFile.output
> > > > > LINKS=/dscratch/osg/app/osg/jtie/duplicate.sh
> > > > > OUTS=simpleFile.txt
> > > > > ln: creating symbolic link
> > > > > `duplicate-gt7hyvgi//dscratch/osg/app/osg/jtie/duplicate.sh' to
> > > > > `/dscratch/osg/data/osg/jtie/simple-wf-xgh9e9q1z0af2/shared//dscratch/osg/app/osg/jtie/duplicate.sh':
> > > > > No such file or directory
> > > > > under dir /dscratch/osg/data/osg/jtie/simple-wf-xgh9e9q1z0af2/shared:
> > > > > seq.sh, simpleFile.txt, wrapper.sh
> > > > > under dir /dscratch/osg/data/osg/jtie/simple-wf-xgh9e9q1z0af2/duplicate-it7hyvgi:
> > > > > one directory - simpleFile.output
> > > > > /dscratch/osg/data/osg/jtie/simple-wf-xgh9e9q1z0af2/duplicate-it7hyvgi/simpleFile.output:
> > > > > empty
> > > > > I think the swift program is right, since I run it successfully using
> > > > > localhost duplicate.sh.
> > > > > Many thanks,
> > > > > Jing
> > > > > > So when the output files are not created, there can be two reasons:
> > > > > > 1. The specification of what files should be created is broken. This is,
> > > > > > at this time, done by looking at the filenames of the return values from
> > > > > > the atomic procedure. Normally one passes those file names to the
> > > > > > application as output file parameters. Example:
> > > > > > (File f) proc(...) {
> > > > > >   app {
> > > > > >     myapp ... "-o" @filename(f);
> > > > > > 2. The specification is correct, but the application doesn't behave.
> > > > > > Mihael
> > > > > > On Fri, 2007-09-07 at 12:35 -0500, Jing Tie wrote:
> > > > > > > Hi,
> > > > > > > I tried jobmanger-fork instead of jobmanager-condor on osg.hpcc.nd.edu site:
> > > > > > > <recall the site used to have the exception - kickstart executable
> > > > > > > (101-FBchannel18_cwt-avgResults.Rdata) not found>
> > > > > > > jobmanager-fork:
> > > > > > > Application exception: The following output files were not created by
> > > > > > > the application: /dscratch/osg/app/osg/jtie/SIDGrid/wavelet.sh
> > > > > > > globus-job-run osg.hpcc.nd.edu/jobmanager /bin/ls -al
> > > > > > > /dscratch/osg/data/osg/jtie/sid-wf1-2g48a936yixu1/cwtsmall-0bhnnvgi
> > > > > > > lrwxrwxrwx  1 osg osgusers   93 Sep  7 12:42
> > > > > > > 101-FBchannel10_cwt-avgResults.Rdata ->
> > > > > > > /dscratch/osg/data/osg/jtie/sid-wf1-2g48a936yixu1/shared/101-FBchannel10_cwt-avgResults.Rdata
> > > > > > > ... (total 28 links, the same number as the number of the expected output files)
> > > > > > > drwxr-xr-x  2 osg osgusers 4096 Sep  7 12:42 101_FB-epochs.Rdata
> > > > > > > drwxr-xr-x  3 osg osgusers 4096 Sep  7 12:42 scripts
> > > > > > > -rw-r--r--  1 osg osgusers   58 Sep  7 12:42 stderr.txt
> > > > > > > -rw-r--r--  1 osg osgusers 4109752 Sep  7 12:41 101_FB-epochs.Rdata
> > > > > > > drwxr-xr-x  2 osg osgusers    4096 Sep  7 12:41 scripts
> > > > > > > -rw-r--r--  1 osg osgusers     571 Sep  7 12:41 seq.sh
> > > > > > > -rw-r--r--  1 osg osgusers    3278 Sep  7 12:41 wrapper.sh
> > > > > > > empty kickstart directory
> > > > > > > globus-job-run osg.hpcc.nd.edu/jobmanager /bin/cat
> > > > > > > /dscratch/osg/data/osg/jtie/sid-wf1-2g48a936yixu1/status/cwtsmall-0bhnnvgi-error
> > > > > > > The following output files were not created by the application:
> > > > > > > jobmanager-condor:
> > > > > > > the application: 101-FBchannel20_cwt-avgResults.Rdata
> > > > > > > /dscratch/osg/data/osg/jtie/sid-wf1-3my5pn01t3ov0/cwtsmall-cpteovgi
> > > > > > > lrwxrwxrwx  1 osg osgusers   76 Sep  7 13:01 101_FB-epochs.Rdata ->
> > > > > > > /dscratch/osg/data/osg/jtie/sid-wf1-3my5pn01t3ov0/shared/101_FB-epochs.Rdata
> > > > > > > drwxr-xr-x  3 osg osgusers 4096 Sep  7 13:01 scripts
> > > > > > > -rw-r--r--  1 osg osgusers   70 Sep  7 13:01 stderr.txt
> > > > > > > -rw-r--r--  1 osg osgusers 4109752 Sep  7 13:00 101_FB-epochs.Rdata
> > > > > > > drwxr-xr-x  2 osg osgusers    4096 Sep  7 13:00 scripts
> > > > > > > -rw-r--r--  1 osg osgusers     571 Sep  7 13:00 seq.sh
> > > > > > > -rw-r--r--  1 osg osgusers    3278 Sep  7 13:00 wrapper.sh
> > > > > > > I think the descriptions of exception are all right now. The
> > > > > > > difference between fork and condor was that fork created the output
> > > > > > > links to the shared directory, but condor didn't. But the essential
> > > > > > > problem is the output files not being created. I will do more
> > > > > > > experiments to see whether the problem of file system or application.
> > > > > > > Thanks,
> > > > > > > Jing
> > > > > > > _______________________________________________
> > > > > > > Swift-user mailing list
> > > > > > > Swift-user at ci.uchicago.edu
> > > > > > > http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20070909/56e0a325/attachment.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20070909/56e0a325/attachment-0001.obj>
More information about the Swift-user mailing list
