[Swift-user] run of sid-wf1.dtm goes wrong
lixi at uchicago.edu lixi at uchicago.edu
Mon Oct 29 16:42:54 CDT 2007
I ran the sid-wf1.dtm on tp-login2.uchicago.edu, but it goes
wrong.
Here is the running segment:
[lixi at tp-login2 Wavelets]$ swift sid-wf1.dtm
Swift v0.3-dev r1387
RunID: 20071029-1624-7cd88yce
cwtsmall started
cwtsmall started
cwtsmall failed
cwtsmall failed
cwtsmall failed
Execution failed:
        The requested application (cwtsmall) cannot be found
installed on any of the sites.
  You should check your tc.data and sites.xml files, and
make sure that the name (cwtsmall) is not misspelled.
Would you please tell me why it happens and how to resolve
it?
Thanks a lot!
Xi
More information about the Swift-user mailing list
