[Swift-user] no registered callback handler
Michael Wilde wilde at mcs.anl.gov
Wed Nov 14 15:17:36 CST 2007
looks to me like possible errors in tc.data may be causing the initial
illegal char messages.  if you used maxwalltime= did you put 00:20:00
values in double-quotes: "00:30" say?
not sure if this is causing the later gssapi message.
send your sites.xml and tc.data file for a closer look
On 11/14/07 2:11 PM, skenny at uchicago.edu wrote:
> hi all, i'm getting this error regarless of the site that i
> submit to (i've tried uc/anl and teraport). initially was
> trying my own script but then tried 'hello world' and am
> getting the same thing...
> however, when i run my own script it does seem to get as far
> as transferring the input file to the remote site; but then
> fails on trying to run the actual job.
> any ideas?
> RunID: 20071114-1407-g84ac350
> echo started
> 2007.11.14 14:07:21.795 CST: [ERROR] Parsing profiles on line
> 187 Illegal character ' 'at position 65 :Illegal character ' '
> 2007.11.14 14:07:21.798 CST: [ERROR] Parsing profiles on line
> 212 Illegal character ' 'at position 5 :Illegal character ' '
> 2007.11.14 14:07:21.806 CST: [ERROR] Parsing profiles on line
> 248 Illegal character ' 'at position 5 :Illegal character ' '
> 2007.11.14 14:07:21.807 CST: [ERROR] Parsing profiles on line
> 273 Illegal character ' 'at position 5 :Illegal character ' '
> Failed to clean up job
> java.lang.IllegalStateException: No registered callback
> handler for org.globus.gsi.gssapi.GlobusGSSCredentialImpl at 1fc0f04
>         at
> org.globus.cog.abstraction.impl.execution.gt2.CallbackHandlerManager.decreaseUsageCount(CallbackHandlerManager.java:33)
>         at
> org.globus.cog.abstraction.impl.execution.gt2.JobSubmissionTaskHandler.cleanup(JobSubmissionTaskHandler.java:482)
>         at
> org.globus.cog.abstraction.impl.execution.gt2.JobSubmissionTaskHandler.submitSingleJob(JobSubmissionTaskHandler.java:148)
>         at
> org.globus.cog.abstraction.impl.execution.gt2.JobSubmissionTaskHandler.submit(JobSubmissionTaskHandler.java:92)
>         at
> org.globus.cog.abstraction.impl.common.AbstractTaskHandler.submit(AbstractTaskHandler.java:54)
>         at
> org.globus.cog.karajan.scheduler.submitQueue.NonBlockingSubmit.run(NonBlockingSubmit.java:83)
>         at
> edu.emory.mathcs.backport.java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:431)
>         at
> edu.emory.mathcs.backport.java.util.concurrent.FutureTask.run(FutureTask.java:166)
>         at
> edu.emory.mathcs.backport.java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:643)
>         at
> edu.emory.mathcs.backport.java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:668)
>         at java.lang.Thread.run(Thread.java:595)
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
More information about the Swift-user mailing list
