[Swift-user] problem with purdue condor pool
Yuqing Deng deng at mcs.anl.gov
Wed Nov 7 10:36:48 CST 2007
Thanks.  GRAM version 2 works with purdue condor pool.
They have three major different kinds machines in the pool:
Linux/X86_64, Linux/X86_32 and WINNT51/INTEL.
I only tested Linux/X86_64 but Linux/X86_32 should work too.
How do I use them all?  Just give a different entry in to tc.data file
for apps built with different OS/ARCH?
For WINNT, I need to build the apps first.
Yuqing
On 11/6/07, Ben Clifford <benc at hawaga.org.uk> wrote:
> On Tue, 6 Nov 2007, Yuqing Deng wrote:
> > The following command works at purdue:
> > globusrun -o -r tg-gatekeeper.purdue.teragrid.org/jobmanager-condor
> > '&(executable=/bin/hostname) (jobtype=single)'
> That is using GRAM version 2.
> > However, when I use swift with the following in site.xml
> >    <jobmanager universe="vanilla"
> > url="tg-gatekeeper.purdue.teragrid.org/jobmanager-condor" major="4"
> > minor="0"  />
> That tells it to use GRAM v4. That is a totally different piece of
> software.
> Change major=4 to major=2 to tell it to use GRAM v2.
More information about the Swift-user mailing list
